Results 1 to 2 of 2
Thread: Boosting range of wireless mouse/keyboard
    Oct 2002
    2,012
    22
    Default Boosting range of wireless mouse/keyboard
    I made a purchase yesterday of a cheap wireless mouse, the Benq M333, to my surprise the range from the receiver was just 3 feet. Finding this most unacceptable I did a few checks online to see how I could boost the range, I saw people soldering antennas unto the circuit board of the receiver and even inside the mouse, I didnít want to do any modding this dramatic just yet. After some tinkering I figured that I could simply clip near the receiver the wire FM antenna from my stereo, and I was able to boost the signal by as much as 300%! Now I can use my mouse across the room with no lost in signal or the mouse pointer jumping across the screen.
    Apr 2005
    1,333
    You can even boost your wifi by using another simple mod:
    placing the antenna inside an open metal can. The can must then be pointed at the other antenna. this setup is called a 'cantenna'. Saw it on BBC.
    The fox was probably right - they could have been sour grapes.
