Results 1 to 5 of 5
Thread: I'm having Problems with MDX9Lib.dll
    Aug 2005
    140
    Exclamation I'm having Problems with MDX9Lib.dll
    i'm learning to
    use Directx 9 SDk and VS.NET...I did some research and i think i have
    the neccessary files...(VS.NET 2003, Directx 9 SDK and MDX9Lib.dll)
    I have problem when i'm trying to add the MDX9Lib.dll to the Toolbox..
    this is the message i'm getting....
    "The assembly 'C:\Program Files\Microsoft Visual Studio.NET
    2003\IDE\MDX9Lib.dll' could not be loaded. Check that any dependencies
    the file requires are istalled."
    What is causing this and how can i fix it?
    (I dont have the MSDN library installed yet...coud this be the problem?)
    Oct 2004
    4,814
    24
    Maybe u need to install the direct x sdk and use that specific dll from the sdk library.
    1,905
    21
    I am kinda lost as to what you are doing but I recognized that error.
    Go to solution explorer window-->right-click references-->click add new reference-->browse for the .dll then OK. Also make sure that the SDK is properly installed. Dlls are usually placed in the system32 directory.
    1,905
    21
    I thought that was the problem but it seems more complicated than that
    Check this link http://www.gotdotnet.com/Community/U...5-9cb83b30db2b
    1,905
    21
    Did not read that part, I was thinking on a build error.
    I would have to say that maybe you could try copying MDX9Lib.dll from to samples directory and overwrite any files at 'C:\Program Files\Microsoft Visual Studio.NET
    2003\IDE\MDX9Lib.dll' so that the file is present and has the same version as the SDK samples.
    I have to download these to find out for myself.
