Results 1 to 6 of 6
Thread: Wind Power Converter
    1,899
    20
    Default Wind Power Converter
    This is an exercise that I suggest everybody do for their mind
    Yes I know a million designs are out there and most are discarded because they were tried and were inefficient.
    I think it is a good excursive for the mind to design a shape that is new to you irrespective of the efficiency factor.
    This is my design:
    I wish to build it with some form of spiral origami, where I can experience more challenges in just the engineering tweaks in this design process
    This design may be workable on a mountain top with chaotic wind directions
    Selfishness is the gateway to Self Destruction
    Lack of "Wokeness" is to be reincarnated as a tapeworm, whereas more awareness give rise to higher level feelings and relations with others
    5,141
    24
    Interestingly - I was told by persons who do this kind of thing that it's not workable with the current technologies. Or - current at the time.
    A solar setup with wind - considering some of those hybrid panels that JPS had - seemed like a good investment. Was told by installers and maintenance persons that they suck. Persons with wind turbines as well seem to not get as much juice out of them as adding more panels. I guess it also depends on WHERE you are. The wind farms in certain areas seem to do well enough - but would more panels with the current higher wattage output be better than wind?
    Sep 2006
    1,317
    18
    The issue with that design is how manage the air flow efficiently.
    Getting the air in correctly is one thing and probably the easy part but we would have to worry about drag and vorticies and other fluid proprieties as the impella turns.
    How would we maintain the correct pressure inside so air effectively comes in?
    1,899
    20
    I... but would more panels with the current higher wattage output be better than wind?
    Diversification is the goal. For us in Jamaica, straight solar is probably best. But even so, on the very top of big hills/mountains, wind can be very extreme, and run even at nights.
    Quote Originally Posted by BNOVA
    This does not use the same technology as the 3 blade wind turbine which uses a plane/bird wing technology which improves with less drag and controlled vortices (artificially created small consistent vortices rather than random large vortices) and has varying efficiencies for varying wind speeds but is optimized for the wind speed at the location where it is installed. However, I forget to add that the load of the turbine in my design would adjust based on the wind pressure, (Also a feature of some horizontal axis wind turbines like the tri blade). My design is based on brut force of pressure. The load on the impeller would be able to reduce when wind speed is low. It is also close to air tight as possible. It does not matter if the efficiency is less that the theoretic max for 3 blade design, this design is omni direction and intended to work in gusty spots, even storm.
    1,899
    20
    Resources
    Must see videos (all 3) (Please 'Like' to boost YouTube algo):
    How do Wings generate LIFT?
    https://www.youtube.com/watch?v=w78JT6azrZU
    How do Airplanes fly?
    https://www.youtube.com/watch?v=F077WDnB8P8
    Turbulent Flow is MORE Awesome Than Laminar Flow
    https://www.youtube.com/watch?v=5zI9sG3pjVU
    Fun video:
    See Thru Jet Engine
    https://www.youtube.com/watch?v=MgL0GW248mE
    Learning videos on Wind Turbines:
    Are Vertical Axis Wind Turbines Better?
    https://www.youtube.com/watch?v=EM-gCvhQhPU
    Vertical Axis Wind Turbine Aerodynamics and Design
    https://www.youtube.com/watch?v=ldt405jIR0E
    These Wind Turbines have NO Blades!
    https://www.youtube.com/watch?v=iWGfB4najfM
    The Challenges of a Wind Turbine on Your Home
    https://www.youtube.com/watch?v=nPvTH7Siclg
    Back to the Future of Wind Energy Technology with Paul Gipe
    https://www.youtube.com/watch?v=6vb18oXPli4
    Wind turbine design, what to buy, and what to stay away from, wind generators and wind mills
    https://www.youtube.com/watch?v=IUXA5KTQiR0
    The Plane That Will Change Travel Forever
    https://www.youtube.com/watch?v=59A8-rKRs-0
    1,899
    20
    Site share of the week/month
    Lesics - YouTube
    https://www.youtube.com/c/Lesics
    Engineering with Rosie - YouTube
    https://www.youtube.com/c/EngineeringwithRosie
    Undecided with Matt Ferrell - YouTube
    https://www.youtube.com/channel/UCjt...Ti6pXjUbzGHQCg
    Two Bit da Vinci - YouTube
    https://www.youtube.com/c/TwoBitdaVinci
    Warped Perception - YouTube
    https://www.youtube.com/c/WarpedPerception
