Page 4 of 4 FirstFirst ... 234
Results 31 to 38 of 38
Thread: C Problems
  1. #31
    Aug 2004
    2,789
    Default Re: C Problems
    Yeah, getchar(); gives the error:
    Call to undefined function 'getchar'
    The views expressed in the above post are not neccesarily the views of icuucme.
  2. #32
    Oct 2004
    4,814
    24
    yes use systm("cls") .
    UPDATE:
    I am really tired i just realized that i answered the wrong question.
    If you want to clear the screen you can use system() function from stdlib.h. you can consider the system function as a command interface. So to clear the screen you will type system("cls"); in your code.
  3. #33
    Aug 2004
    2,789
    Would stdlib.h affect the code you gave for adding colour?
  4. #34
    Oct 2004
    4,814
    24
    Quote Originally Posted by icuucme
    nope, shouldn't.
    on another side:
    i just realize that system("pause") may not be idle because it always print the text "Press any key to continue . . .", so i'll still try to search for a better method. unless thats ok with you.
  5. #35
    Aug 2004
    2,789
    I deleted the system("pause"), didnt really like message that came up. Didnt need it anyways, the program still runs even without getch(). I get an error when i put in the color class tho.
  6. #36
    Oct 2004
    4,814
    24
    OK, i c.. i'll try a few things in borland later, unless your running on a deadline? I would say leave it out, but if your not i should be able to post a solution later.
  7. #37
    Aug 2004
    2,789
    Thanx, i can wait, i would really want colour in the program without using cprintf
  8. #38
    Oct 2004
    4,814
    24
    LOL, getchar(); is a part of the stdio.h library i can't beleive that missed me.
    Anyways i made the modification tested it and its ok.
