Results 1 to 4 of 4
Thread: need your help
    28
    Default need your help
    so been a year since i used vb.
    i am working on a windows phone 7 app.
    having trouble.
    is there a tutorial for taking input from user and output results based on the input?
    Dec 2005
    1,951
    i know how to do it in c#. I think its the same logics.
    string StoreInfo;
    TextBox userInput=new TextBox();
    StoreInfo=userInput.Text();
    EG....so if youre using the TextBox as a username field.
    if(StoreInfo=="mobile_fan_2k5")
    MessageBox.Show("You Have Logged in Successfully");
    Pc= Hp dv6t
    28
    Thanks but it isnt quite like that.
    i will post how to soon.
    28
    so i found out through a forum that there is a dictonary type. so there is no need for loops.
