Page 8 of 9 FirstFirst ... 6789 LastLast
Results 71 to 80 of 89
Thread: Android "How to:" guide
  1. #71
    Feb 2007
    6,512
    In class now so I'll check the link later but I did select install from sd card and in trying to install it says directory not found. I did everything with clockword downloaded latest cyanogen, backedup and wiped my data.
    ShadowWolfe, signing off *salute*
    /user has permanently disconnected from the Animus.
  2. #72
    May 2010
    3,851
    17
    Quote Originally Posted by ShadowWolfe Hellscream View Post
    ok re-download the rom don't rename it put it in the root of your sd card not in any folders and try again
  3. #73
    Feb 2007
    6,512
    Did again what you suggested but heres the new stuff:
  4. #74
    May 2010
    3,851
    17
    did u use the "choose from zip-card" option? also make sure you are using the correct rom for the phone that may be the prob. What phone are you using?
    Edit: From ur earlier post i gathered that you are using the Samsung Captivate if that is correct your more than likely using the wrong rom... the correct rom for you is http://download.cyanogenmod.com/?device=captivatemtd
  5. #75
    Feb 2007
    6,512
    You know it's my fault cuz what I did was rename all my roms to update1, 2, 3 etc and got all the filenames mixed up and didn't even realize when I renamed the one in my previous post.
    I had downloaded the one off this page http://wiki.cyanogenmod.com/wiki/Latest_Version
    went into cwm and got it working.
    Respex KJ
  6. #76
    May 2010
    3,851
    17
    Respex KJ
    Aight bless up boss glad you get it working
  7. #77
    Feb 2007
    6,512
    Yeah now I don't know what to do with the phone lol
  8. #78
    3,041
    Well now that you got CM7 you can finetune things like processor speed, memory heap etc. Or you could just play around with the overall behavior, look/feel of the phone UI.
    Just remember to backup your rom. Now that you got the nightlies you should keep an eye on the changelogs, and feedback threads.
    http://forum.cyanogenmod.com/topic/2...-of-nightlies/
    Updating to the next nightly is very through rom manager.
    Calm Like a BOMB
  9. #79
    33
    How do i check my phones cpu clock without installing set cpu?
    The rom i installed claimed that is at 1.2ghz at boot. if I install any other overclocking software it will be disabled.
    Is there a way for me to know the cpu clock with a widget or something?
  10. #80
    Mar 2005
    6
    Default Customizing HTC Inspire 4G
    Hi I recently upgraded to this phone, which is similar to the HTC Desire. I haven't seen any thread on the Inspire and would like to know how to customize the AT&T apps that came with the phone preferably the "stocks" and "news" apps.
    I tried to add the RSS feeds from the available local newspapers but there is no option to do that.
    Can anyone assist with this please?
