Rooted OnePlus 2 64GB Ed, Android 5.1.1 OxygenOS ; on teifin' AT&T's network; Rooted ASUS Transformer TF101 w/ dock, Android 5.1 KatKiss; Laptop: ASUS X550C, 2.0GHzx2, 8GB, 512GB SSD, Kubuntu 15.10;
Facebook page: Skeleville Technology Solutions
Guess I'll use
unless someone has something better.Code:printf("Please enter the First name then Surname name of a student.\n"); scanf("%s%s", &name, &name1);
Project > http://naturaldisastertips.com
You could also look at the gets() function. I do recall hearing that it is not recommended but it works.
http://www.cplusplus.com/reference/c...y/cstdio/gets/
3.14159265358979323846264338327950288
4197169399375105820974944592307816406
28620899862803482534211706798 pi 101
Having a problem with this loop..
I need it to check for a file if the file doesn't exist it prompts the user to enter the name of the file they want to read until they enter the right file name
Currently usingCode:int read() { char filename1[50]; printf("Please Enter the name of the child whos report you would like to view.\nNo spaces between the names & This is case sensitive\n\nExample : RicardoMcdonald\n"); scanf("%s", &filename1); strcat(&filename1, ".txt"); FILE *fp=fopen(filename1, "r"); while(fp==NULL){ system("CLS"); printf("There is no report on the student entered\n\n"); printf("Please Enter the name of the child whos report you would like to view.\nNo spaces between the names, This is case sensitive\n\nExample : RicardoMcdonald\n"); scanf("%s", &filename1); FILE *fp=fopen(filename1, "r"); strcat(&filename1, ".txt"); } system("CLS"); printf("File has been found"); system(&filename1); printf("File has been sucessfully open\n"); fclose(fp); retmenu(); }
Should i just stick with what I'm using currently? returning to the main menu would give the option to get back into this menu.Code:int read() { char filename1[50], namee[10000]; FILE *fpp; fpp=fopen("C:\\reportscreated.txt", "r"); if(fpp == NULL) { printf("I'm sorry but for an unknown reason the text file which stores the names was not created\n"); }else{ while(fgets(namee,10000,fpp)!=NULL); { printf("%s", namee); } printf("\n"); } printf("Please Enter the name of the child whos report you would like to view.\nNo spaces between the names & This is case sensitive\n\nExample : RicardoMcdonald\n"); scanf("%s", &filename1); strcat(&filename1, ".txt"); FILE *fp=fopen(filename1, "r"); if(fp==NULL) { system("CLS"); printf("Please try again, You will now be returned to the main menu.\n\n"); error(); } while(fp!=NULL){ system("CLS"); fclose(fp); printf("File has been found\nFile has been sucessfully open\nWhen done viewing file please close it to return to main menu\n"); system(&filename1); retmenu(); } } int error() { printf("There has been an error!!\n"); retmenu(); }
Also how can i display things from a text file I have a list of names i would like to display and
Only displays the last name on the list only.Code:while((fgets(name ,500, fpp)!=NULL);
First, there's at least one bug in the first code section. Check your pointer declarations . Next, there's alot of redundancy in that same first section. I suggest you use a do...while instead of repeating the same process outside and inside the loop. BTW, I'm loving how you unconditionally force people into entering a name . Finally, could you please properly indent your code? It'd make it so much easier to read. Both for you and us ...
well to use fgets i'd have to change most of my code.. I found a way though
scanf("%[^\ns", <variable>); Works perfectly just incase there's anyone else with such a problem
What i need now is help with checking if a interger is a char
You mean a letter right? Just check if it's between the ASCII values. 64 - 126 I think; don't quite remember exactly...
