Pezz (Gaza)
Dejeany (Gully)
you seem to feel persons here are idiots right?
where is the proof? you seen my 4.1ghz post right? am I stable? NO . where are the temps you getting with 1.552 volts on load and idle with a xigmatek? All you did is boot and after machine settled you used the software to overclock one core on the machine and took a screen
what problem the man have? you persons are simply LIARS . When things arent possible it just is just not possible . I am sure Rizzle knows the capability of a xigmatek cooler. I also have one in my closet because it fails at over 1.45v . So there is no way it can win at 1.552v
you now it is clear, I knew that sorry excuse for a tutorial cannot lead to any massive temp drop you guys claim that you got.
just a hint ... NOT EVRYONE ON TECHJA IS AN IDIOT
you GUYS FAIL . Good try at trying to trick the less knowledgeable though
4870 x2 40C up idle..50s under load...before i cleaned it, crash...so doe kno wah u tlkin bout on the vid cuz those were the temps after
Um what fan speed u have that x2 at? cause 40c sounds pretty low given that my 4850 used to idle at around 55c with the stock cooler.
EDIT: and my 3870 idles at 41 on liquid!!!
http://vanguardtec.blogspot.com/
iNtel i5 3570K-Gigabyte G1 Sniper M3-8GB DDR3-ATi Radeon 6870 1GB
well i did not say i was running it at 4Ghz all the time because that will cause system degradation and shorten the life span of my cpu
