Results 1 to 6 of 6
Thread: *120# hot fix
    Dec 2005
    365
    Default *120# hot fix
    here is the steps to get *120# and other ussd commands wroking on the storm
    Go to “Options” – “Mobile Network” – put “Data Services” in the off position – “Network Selection Mode” should be “Automatic” – “Network Technology” should be “Global”. After completing these steps, turn the phone off then remove and replace the battery – All should be well. After processing the USSD codes for BB services you will need to re-enable Data Services in the Mobile Network Options Menu in order to gain data services
    storms users please post results
    STGC 4 LIFE __________________95-2000
    Blackberry 9550
    blackberry 0 (active)
    BLACKBERRY ALLIANCE MEMBER
    Feb 2006
    4,242
    started here: http://www.techjamaica.com/forums/sh...ad.php?t=78364
    Thanks for the info, will try it out.
    --- www.fashionsJAMAICA.com ™ -|- www.ChampsJamaica.com
    Jan 2005
    4,562
    Did for my bredrin and working
    Dec 2005
    365
    did it on my storm a my frends 2 storms worked great
    Blackberry 9550
    27
    what was the problem that this fixes?
    Aug 2005
    5,306
    Quote Originally Posted by Bigpipin View Post
    The issue was once you dial *120# on the Storm 9530 Blackberry it automatically makes a call instead of checking your credit on the network, CAPEECH
    Ricardo Barrett
    Jesus+Education=Success
    BBM ME @ 7A70FCE3
    Whatsapp 1(876) 783-8991
