Results 1 to 10 of 11
Thread: Help with is java script function
    May 2004
    530
    Default Help with is java script function
    I have this javascript function that for some unknow reason does not work , can any one please help.
    function STUDENTID(){
    	var x=document.getElementById('level_adm').value
    	 if(x != "parent" || x != "student"){
    	document.getElementById('studentid_adm').disabled = true
    	}else if(x == "parent" || x == "student"){
    	document.getElementById('studentid_adm').disabled = false
    "...men are that they might have joy."
    Nephi
    13,269
    34
    Well, looking at the function alone, we won't be able to fully understand where the problem, might be. Function looks ok as to it's proper syntax. But don't know what studentid_adm or level_adm that it is trying to access. A button? A text box?
    Do you not have a javascript debugger ot javascript console to look at when you run this code? Firefox has both you can use, to see if a error is generated.
    Maybe you could add the accompanying html code so we can see the whole thing in it's context.
    May 2004
    530
    Quote Originally Posted by Arch_Angel View Post
    The thing is the script work perfectly like this :
    	if(x != "student"){
    	}else{
    but when i try to evaluate the variable value as shown in the first function it does not work. All i m doing is checking what is the value of x.
    Nephi
    13,269
    34
    Hmm ok.
    Why not leave out the 2nd if statement. In fact, code it in a more positive way.
    	}else{
    BTW, what's the outcome after you run your function? Is studentid_adm disabled or not?
    May 2004
    530
    Hmm ok.
    	}else{
    Thank you so much that worked perfectly
    Nephi
    May 2004
    530
    Default show / hide
    What is i wanted to do a show hide based on the value of the x variable how would that work. I have tried this but no success.
    <script type="text/javascript" language="javascript">
    	var x=document.getElementById('Level').value
    		document.getElementById('studentid_adm').style.display = 'none';
    	}else{
    		document.getElementById('studentid_adm').style.display = 'block';
    </script>
    Nephi
    13,269
    34
    Since I can't see your CSS or HTML, I'll just outline what you need.
    - You need your javascript function that changes the style attribute of the DIV you are trying to hide or show. You javascript looks ok.
    - You need your html with a division (or a similar tag) with an id of 'studentid_adm'. It's a division you are hiding? If not...what?
    - You need your CSS that sets the style display of the division. This is optional I suppose.
    - You need a link to call the javascript function.
    Have all that in place? Any javascript errors? What happens when you try to hide or show the division?
    May 2004
    530
    the only thing i have changed is to give the studentid_adm to a div instead of a text field, so i dont see why it should not work. No JavaScript errors. Nothing happens when i try to cal the division.
    Nephi
    13,269
    34
    The value of X would have to be changed when clicking the link to hide or show the division. Or you setting the X value each time the function is called?
    May 2004
    530
    Quote Originally Posted by leocrawf View Post
    Found the error, there was a " missing from the drop down onchange call :
    was
    <select name="Level" id="Level" onchange="STUDENTID()>
    should be :
    <select name="Level" id="Level" onchange="STUDENTID()">
    of course you could not see that.
    Nephi
