Hey Techjamaican?
I have a new version of the USB loader GUI version and it's much better than the previous. Check it out.
This loader is based on the original by Waninkoko (v1.1) with many features of his v1.5. So far SD-support is not implemented.
I hope we can grant most of your wishes and we will try to keep your suggestions in mind. Anyway we are thankfull for all suggestions, bug reports etc. I know that there will be modifications soon but PLEASE don't post all of them here. If it's some good feature or something that helps to improove this loader talk to one of us first and then post it.
Coders/Members: Dimok, Neorame, WiiShizza, Hungyip, nIxxx, giantpune and Cyrex
Changelog (important changes only): rev98
* little correction of the main menu buttons
* added credit window
* changed scrolling now you need to press B and you can scroll
* changed lock now you will see the Install Button but it does nothing if password wasn´t entered
* inserted keyboard to enter password (still the same "AB121B"), if the password is wrong or not entered the install and delete buttons are disappearing
* fixed excite truck bug (THX to 56killer)
* fixed some buttons and positions
Features:
* disable install/delete (to enable it go to settings and press AB121B)
* GUI is completely based on the awesome libwiigui
* GUI is designed like the orignal Nintendo Wii Menü (main menu and settings menu)
* loads game boxart and cd covers from the SD-card
* boxart fades into the screen
* cd covers (if the have the correct size and shape) will look awesome while they are spinning smile.gif
* disc slot lightup in game menu
Buglist:
Please enter every bug you notice in the "Issues" section of googlecode HERE
* "Go Diego go Great dinasour rescue" doesn't run on the loader(NTSC Wii/ NTSC game/ not patched).
* pressing the power button on wiimote doesn't really shutdown the wii (green power light on wii stays on but screen shows nothing)
* after locking install/delete there are two buttons, one says "OK" and the other says nothing
* after locking install/delete starting a game freezes the wii (game was Wii Music)
* if you unlock and then lock again delete/install you can still add and delete.
* scrollbar isn't acting correct when you grab the bar ("acting weird")
* longer loading time through forwader
* sometimes freezes the wii (depends on the low resources of the wii, will be fixed by code optimization but doesn't seem to happen on every wii)
Wishlist:
* diskslot lightup when installation of a game finished
* dark overlay for the backup during WindowPrompt instead of white one
* customizable button mapping via config (for install/delete/parentcontroll etc.)
* implement save settings to SD-card
* theme support
* downloadable covers (on/off in settings)
* channel animations instead of boxarts (read the Opening.BNR from the ISO)
* favorite games/categorize games
* change keymapping on the d-pad
* set the behav. of the "Wii"button in settings (to HBC or Wii Menu)
* widescreen support
* include titles.txt
* "childmode"
* scrolling text for longer gamenames
Boxarts/DVD covers:
* Boxart images need a resolution of 160x224 and must be place in SDRoot:/images/
* DVD covers image need a resolution of 160x160 and must be placed in SDRoot:/images/disc/
* DVD and Boxart images must both named like this RUUXEP.png for example (6digit GameID) or 3digit GameID or it loads the default.
* DVD covers should be centered with a transparent background for better look.
DOWNLOADS:
USB ISO Loader GUI: http://www.tehskeen.com/forums/attac...5&d=1240294306
Giantpune's 500 Disc Cover Pack: http://www.megaupload.com/?d=1LDOBQKI
ppmies's 1418 Box Art Pack: http://www.megaupload.com/?d=FNPJAZYF
