need some help never yet do programmin in ma life & mi get a project & dont kno wht to + mi did miss the first week out of sch cause mi never kno say the sch start now the first day of class for me i run in to a project an dont kno ntn.
pseudocode is basically the process the code go through, but you will write out the process.
I would suggest you do some search in google on pseudocode to get a better understanding of what is require and this will become straight forward for you. It basiacally similar to the flow chart as well. Just stating the process really.
can any 1 do # 1 for me plz
http://en.wikipedia.org/wiki/Pseudocode
give dis a reed
Do the research, make an attempt at completing the task and then ask for help if you encounter a problem. Someone doing it for you won't help you develop your basic programming skills.
$10,000 and mi do this assignment
Phenom X4 9550, MSI K9N2 SLI Platinum, Kingston HyperX SLI 4GB DDR2 1066MHz, Evga 9600GT Supaclack'd, Corsair 750W PSU,80gb 2.5 5400rpm X 2- Raid 0
kevin@4046263 Kevin1386@gmail.com
Kingston/Portmore/Mandeville
@ kevin1386. Times really hard.
Pseudocode and flowcharts are basically two ways to show the possible paths a job/instruction can take to be completed. Just think about a day in your life: wake, bathe, eat, get transport, go to work/school, etc. as an example.
Think of how you'd solve the problem (#1). Break the problem down into several smaller ones as you go on. Solve each small problem. Write the steps you use to solve the problem. There, you got pseudocode! Flowcharts are essentially a graphical pcode...
Rooted OnePlus 2 64GB Ed, Android 5.1.1 OxygenOS ; on teifin' AT&T's network; Rooted ASUS Transformer TF101 w/ dock, Android 5.1 KatKiss; Laptop: ASUS X550C, 2.0GHzx2, 8GB, 512GB SSD, Kubuntu 15.10;
Facebook page: Skeleville Technology Solutions
i really need a start for the pcode.. how would i start it
tell me if i am on the rite track people
Begin
character cName, cSex, cIdentificationNumber cPhoneNumber, cAddress
Numeric nEntryLevelForm, nAvailableEntryLevelForm
Display "Enter Member Name"
Accept cName
Display "Enter the age of member"
Accept nAge
Display "Enter the sex of member"
Accept cSex
Display "Enter Identification Number"
Accept cIdentificationNumber
Display "Enter Phone Number"
Accept cPhoneNumber
Display "Enter Address"
Accept cAddress
Read members from the database
Logic looks ok so far. Don't think you really need the declarations or "Displays" now though. You're just describing the process to take, not writing program code. From collecting the info to verifying and writing to the database.
Ask some classmates to help you out so you get the methodology guidelines.
