December 1, 2004, 02:53 PM
#1
Motorola C333 problems
Has anybody bougth the new motorola c333 and is currently using it as a modem.
I bought one, but i am not pleased with it. I used to have the c332 and It worked pretty well, but somebody stole it. I got myself a c333 and hooked it up, but it is moving sluggish. The signal keeps dropping and i get disconnected pretty often?
I wanna know if i should carry back the phone.
Is anybody experiencing the same or similar problems?
December 1, 2004, 08:51 PM
#2
Re: Motorola C333 problems
ist this with Digicel or CE ??
December 1, 2004, 10:34 PM
#3
December 1, 2004, 10:37 PM
#4
I'm talking the C&W motorolla c333.
December 2, 2004, 04:39 AM
#5
work fine, but regardless of 115.2 kbs. i still find it very slow
December 2, 2004, 06:50 AM
#6
it does seem to boot me off when it ready still, i never got that problem with my c332 either.
December 2, 2004, 08:38 PM
#7
Dont expect dsl speed these phone only have a 56k modem.
December 2, 2004, 11:15 PM
#8
I use the C333 and have little connection issues. Check the service level and make sure the antenna is not covered.
December 3, 2004, 09:15 AM
#9
Can someone post the C333 win98se modem drivers?
December 3, 2004, 09:54 AM
#10
Come on man do better than dat a 2004 now at lest get WIN 2000, and the driver for Cxxx phones will be easy to get.
