Nov 15, 2004, 12:46 PM
#1
HELP - Need To Unlock Nokia 3595
I need to unlock my Nokia 3595 (CWJ), I wish to unlock the phone without a data cable as I don't have one nor access to one. Can anybody HELP?
Nov 15, 2004, 12:50 PM
#2
Re: HELP - Need To Unlock Nokia 3595
post your imie num and i'll get u the unlock sequence its really easy to do yute..
Nov 15, 2004, 12:56 PM
#3
Nokia 3595 (CWJ)
IMIE Num: 010260/00/068051/0
Nov 15, 2004, 01:49 PM
#4
Nov 15, 2004, 04:19 PM
#5
What CWJ Network Code??
Nov 15, 2004, 04:27 PM
#6
cw network code is 338180
Nov 17, 2004, 02:16 PM
#7
So does anybody have the software that i can use to unlock the phone without the data cable?? Please forward the link, thanks.
Nov 17, 2004, 03:42 PM
#8
Try #pw+806271546756616+1# report if itworks
Nov 17, 2004, 03:44 PM
#9
For the software check gsmcoder.com form your phone.
Nov 17, 2004, 07:20 PM
#10
something additional, just in case u don't know, u have to remove ur chip, then turn the fone on & put in that code that marlonxp gave u. u get +, p & w by pressing * repeatedly. I'd advise that u also double check while u inputting & only try it twice.
