Results 1 to 10 of 13
Thread: Monitor issues
    Aug 2004
    398
    Unhappy Monitor issues
    My monitor every now again just goes dead. If i plug it out and plug it back in, i keep hearing a clicking noise. It normally makes one click when it's turning on, but now, its just click click click and nothing.
    Anybody had similar problems and know how it can be fixed or if it can be fixed?
    --- Bless, 24 HRS !!
    6,223
    Default Re: Monitor issues
    What kind of power is going into the monitor? Straight JPS, UPS? Have you checked the Voltage? Is the monitor 50/60HZ?
    PC - Ubuntu 15.04 64bit Desktop
    HP Pav G60-236US 3GB RAM Laptop, Ubuntu 15.04 64bit and Win7 Home
    RIP Ramesh ...
    Aug 2004
    398
    JPS power. The monitor has been working for a couple of years and it still does, just not all the time. Its actually working now but i'm just waiting for it to kunk out again soon. How would i check the voltage and those stuff?
    6,223
    You can go to a hardware store and obtain a voltmeter, better still an all-in-one meter. Sample the voltage at different times and with different loads and see if it varies greatly. Also, your monitor may have been hit by a voltage spike, extremely common in Jamaica. Best to have it checked by a certified technician.
    You should always plug your computer and monitor into a UPS.
    RIP Ramesh ...
    2,546
    dont even try checking any voltages. monitors carry thousands of volts inside and also have very trong mag fields. leave it to a techie who does that sort of thing.
    a part is failing and you need it serviced without doubt. the switching indicates maybe an electroinic fuse that trips with either over current or heat.
    do not open the monitor back!!!
    Aug 2004
    398
    I'd never even think of opening it still. I'm not on those levels. I'm wondering if heat really does have something to do with it. The room its in can really get hot sometimes and a few times earlier i'd put a fan on it and then after a while it would work.
    I just really wanted to make sure that its something that can be fixed cause really and truly its a 19" and i dont want to see it go. The next time it goes, i'm carrying it to be repaired. Anybody knows any good place i can go with certified technicians and ppl who wont rob me?
    Aug 2004
    398
    Oh and i dont have a UPS but i do have a good surge protector.
    6,223
    Quote Originally Posted by deakie
    My bad. I meant at the wall outlet, not in the monitor itself!
    RIP Ramesh ...
    Jun 2004
    3,547
    24hrs 4 gran can get you a brand new ups. i highly recommend getting one.
    Aug 2004
    2,789
    the prob could also be the heater in the monitor. it could be going..i had a prob like that. go to a pc repair store and get a new heater..when the monitor goes do u see anything at all on the screen? even a white line?
    The views expressed in the above post are not neccesarily the views of icuucme.
