--- www.fashionsJAMAICA.com ™ -|- www.ChampsJamaica.com ™
I want to get the site looking in IE6 like how it looks if Firefox 3. The valign="bottom" and allowtransparency="1" is not working in IE6
How can I fix it?
CSS:HTML Code:<td colspan="3" rowspan="7" background="images/index_19.png" valign="bottom"> <!--iframe to display each links--> <iframe src="home.php" allowtransparency="true" name="iframe" class="iframe" > </iframe> </td>
Internet Explorer 6HTML Code:.iframe { font-size: 16px; background-position:bottom; border:none; display:inline; font:Arial, Helvetica, sans-serif; color:#000000; height:93%; width:98%; }
Firefox 3
in the home.php file set the <body> background to the same backgroud color as the rest of the site. avoid non-standard tags if you want to remain sane
Check out My Awesome Blog & News Jamaica
Ok that's is for the bgcolour.
Now I need the iframe to be positioned at the base.
valign="bottom" in the td tag and align="bottom" in the iframe tag is not responding in IE6.
home.php is just a simple: fopen() (so far)
Why didn't you consider dynamically loading the content into the 'content' area. this would be a simple line of code using jQuery or prototype javascript libraries.
jQuery.load('content', 'objectives.php');
I guess this would need javascript enabled, but would simplify/eliminate your CSS problems with iframe. (i know you will need one of them js libraries later on to pimp it out Web 3).
just my opinion (it cant be wrong or right).
your opinion is very wrong. If you read the thread you would notice that the guy is new to HTML and webdev. Your suggestion is neither simple nor will it simplify/eliminate his CSS problems with iframe. In fact, it may (when all is said and done) corrupt his mind. @Utech22 disregard his post.
My opinion is neither wrong, nor very wrong, it is in fact right.
He was new to this a long time ago, and should not rule out a proper solution just because he is new. he is also new to iframes and he is having problems with it (as does the browser, even though iframe is not new to the browser).
happy to know you still regard it as the solution. it is one line of code simple (and no brain work).
it will eliminate him having to know which attributes work and which dont.
if he can get this to work on a single page, just cut out the portion from the content area an put in a separate php file.
lots of people have been corrupted by simple solutions before. in fact, (when all is said and done) simplicity is a good thing.
Sure, @Utech22 disregard my post. for when it comes to php only some posts must be read. and this is not one of them.
programming is about solving problems, not working your way into a different one which is no easier solved.
owen you are a php genius. i offered a non php solution, a solution never the less. this is about problem solving, not php.
I may just use a script to detect the browser
and align the iframe accordingly.
javascript is my last resort, I don't like using it, only if absolutely necessary.
There is other work around that i can do:
eg. slide the bg image, so that the header (Welcome) stands alone.
