Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Thread: XP SP3..post results and thoughts
    Jan 2005
    1,096
    no difference noticed yet
    Dude, Aren't the "good things that come to those who wait" just the leftovers from the people who got them first.
    Feb 2005
    1,954
    Quote Originally Posted by Nestersan View Post
    To be honest, it feels a bit snappier overall, but that's it so far, I have gamed and opened some documents, seems ok, I can roll back if it ****s it self.
    ok cool thnx, let us know if you experience any issues using it. I think i may download it to my work pc and see whats up with it
    MATADOR: GIGABYTE GA-EP45-UD3R, C2Q Q9400 @ 3.4GHz, ZALMAN CNPS9500, 6GB GSkill, Crucial C300 SSD 128GB, 2x 2TB WD Caviar Black, Diamond HD5850, 2x Plextor DVD+RW, RAIDMAX Scoprio 668WBP Case, Rosewill Xtreme Series RX850-D-B 850W, Dell E228FP WideScreen 22", Logitech Z-2300, Windows 7 Pro x64
    6,327
    What sort of new and enhanced functionality does SP3 contain?
    Some features of note include:
    Improvements to “black hole” router detection.
    Network Access Protection, which is a network policy enforcement platform previously seen in Windows Vista and Windows Server 2008.
    Enhanced Control Panel Security Options which better explains the impact of the various settings.
    Product key-free installation now possible.
    What’s the purpose of SP3?
    According to Microsoft, the goals of SP3 are:
    Provide a new baseline for customers still deploying Windows XP, to help them avoid the inconvenience of applying individual updates.
    Fill gaps in the updates users might have missed by declining individual updates when using Automatic Updates, and to deliver updates not made available through Windows Update.
    How big is SP3?
    Depends on how you get it. Through Windows Update the typical download will be in the region of 70MB. Through the Microsoft Download Center the download balloons to around 580MB.
    What versions of XP can SP3 be applied?
    Any 32-bit version of Windows XP SP1 or SP2.
    Can SP3 be applied to Windows XP x64?
    No. Users of the 64-bit version of Windows XP should download and install Windows Server 2003 SP2.
    Does SP3 include Internet Explorer 7?
    No, IE 7 is not part of SP3. However, updates for IE6 and IE7 are included.
    If I install SP3 and something goes wrong, can I uninstall it?
    Yes.
    Does SP3 improve system performance?
    If it does, Microsoft isn’t letting on.
    --- http://blogs.zdnet.com/hardware/?p=1705
    So i guess thats about it then..
    Let Them Hate, So Long As They Fear.
    You do not know whereof you speak,and your words are empty things.
    Listen and gain Wisdom.
    http://twitter.com/nestersan
    Oct 2007
    241
    Ive installed SP3.......Havnt noticed any difference in the OS yet.
    The only Contsant in life is Change
    AMD for life....up yours INTEL .........Oh wait ther's the Corei7
    Jan 2005
    3,112
    Nesty bus wi pon di link nuh man... cho... even though mi nuh need it so urgent as my rig is now XP 64 Bit... and loving it... no big difference from 32 bit... all drivers are ok... and my 4 GIGS of ram fully recognised... time for 8gb....
    cell: 807-4523| email: mysonchug@yahoo.com | PM Me
    13,270
    35
    Quote Originally Posted by MaxFactor1 View Post
    Can SP3 be obtained legally?
    It will be released on the 29th from MS. Can hold for another 24-48 hours.
    2,460
    i have teh RTM .. link up.
    just member say if u nuh str8 everything get fawc
    6,327
    like what ?
    the nag thing ?
    lolers...
    Oct 2005
    182
    works fine for me. My system has a 2ghz celeron, 1gb of memory
    Jun 2005
    151
    i dont see much effect on mine either
    Laptop: Sony Vaio
