Results 1 to 10 of 11
Thread: HELP!! Laptop Dialup Connection
    120
    Red face More HELP!! Laptop Dialup Connection
    I have been having problems configuring my laptop to accept dialup connections but the option is grayed out in the how do you want to connect to the internet section of the wizard.
    and I have no Idea why I cant enable that.
    I have to access the internet through my PC's connection using a crossover net cable.
    have a toshiba brand, help me out because I am a novice
    6,223
    Default Re: HELP!! Laptop Dialup Connection
    Quote Originally Posted by swollen_i
    Check if your modem is enabled.
    PC - Ubuntu 15.04 64bit Desktop
    HP Pav G60-236US 3GB RAM Laptop, Ubuntu 15.04 64bit and Win7 Home
    RIP Ramesh ...
    120
    Quote Originally Posted by ramesh
    I checked that ramesh and it is enabled, got any other options??
    Mar 2004
    707
    I think it could be because your system is set to connect to the internet via a network. This could have been done when you were setting up your network. Try reconfiguring your network connection and where it asks if it connects to the net on its own or through the network, choose the first option.
    01001101011110010010000001101001011011100111010001 10010101101100011011000110100101100111011001010110 11100110001101100101001000000110100101110011001000 00011100000110010101110010011100000110010101110100 01110101011000010111010001100101011001000010000001 10001001111001001000000110110101111001001000000110 00110110111101101101011011010110111101101110001000 00011100110110010101101110011100110110010100101110
    Click Here for translation
    120
    Quote Originally Posted by blindz
    but yu sharp, ah wonder why u name blindz I think yur on to something B I am going to check it now. dont know why me neva check dat
    120
    I followed your advice blindz and was checking the network settings and you were right I had the option selected to connect through another computers internet connection. I changed that to the option "the computer connects directly to the internet" - still dont work - the dialup options are still grayed out - I think ah missing something.
    I was fooling around and found that I could add a dialup connection from the control panels internet options
    I got an error when I was trying to add a connection
    The Remote Access Service Manager could not start
    I dont know what this is, I checked the services and found it but I cant start it, it is saying that error 5 permission denied.
    Mar 2004
    707
    Bwoy, I don't know, life hard for u, r u sure that u r the administrator for the system?
    120
    I formated my HD and it worked, did not want to do that but it was a last resort
    120
    When I had formatted the drive and the downgraded the OS back to Home Edition and the option came up I thought that I had some misconfiguration issues, however I found out that I only have this problem whenever I try to upgrade to XP pro.
    Can you guys point me in the right direction as to what I am supposed to be looking for to fix this.
    Aug 2004
    321
    Am try this i have just breezed through your post but what i think is happening to you is that the server option is not enabled and hence RAS(Remote access server) is not starting. Am go to network connections and look @ the top you will see on the bar File, Edit,.... Advanced look in there under optional i think you might want to select a few of those things.
