Good stuff, nice post....
When you're outside of a domain environment, XP has some features missing. XP Home leaves you completely without the Group Policy Editor, while XP Pro lacks the ability to use the Group Policy Editor to selectively apply policies to specific users.
Well, that's about to change.
Doug's Windows XP Security Console allows you to assign various restrictions to specific users, whether you're running XP Pro or XP Home.
Click here for screen shots of the program
Support for Windows 2000 - No support is offered for this utility, running under Windows 2000. It may run, it may not. I do not support this utility, running under Windows 2000, and cannot guarantee its compatibility.
Release notes:
v1.3.5 - Correct a few minor bugs. Removed the "Block Attachments" setting in Outlook Express (doesn't work on a per user basis). Support for new licensing method. Added the ability to back up and restore any 'machine wide' registry settings that may conflict with the use of this utility.
v1.3 - Added support for restricting access to specific applications on a per-user basis (licensed version only).
download here
http://www.dougknox.com/xp/utils/xp_securityconsole.htm
NB. this is the Xp version for the group policy (gpedit.msc) feature in vista
I Now Have the Highest OC on Techja 4.2Ghz
GekkoState™:Gigabyte X58 Extreme | Intel Core i7 940 OC @ 3.08Ghz cooled by Noctua NH-U12P SE1366 | Corsair Dominator DDR3 -6x2Gig |2 EVGA E-GEFORCE GTX 260 Superclocked 602MHZ 896MB 2.052GHZ GDDR3 In SLI |22"Widescreen Phillip LCD l Logitech G15 Keyboard | Logitech G5 Laser Gaming Mouse | 18x + 22x Samsung Sata DVD+RW | Western Digital Caviar 2.8 TB | Antec 1200 Gamer Case | Enermax Galaxy Dxx 1000 Watt Psu | Windows 7 Ultimate
Let Them Hate, So Long As They Fear.
You do not know whereof you speak,and your words are empty things.
Listen and gain Wisdom.
http://twitter.com/nestersan
Let me add something to this post.... you can do this.. and more.. using the build policy editor in Windows... from 2000 up..
It can allow you to manage every thing from windows messenger to Application that support Policy editing to Password Complexity and Duration and so on...
Simple go to control panel -> Administrative Tool -> and open Group Policy....
However if you dont see this on you machine.. create your own management console...
just go to run and type "mmc" (witout the quote)
then from there go to file --> Add Snap In. and you can add wat you want... Group Policy is what allow you to manipulate these settings...
or use the gpedit.msc from the run command to use the precreated gp console.
In addition if you have Admin Rights over a network computer you can create the Snap of that machine.. and mess with its... Policy
Why fight Information Technology when you can outsource IT
thanks.....![]()
Yow been waiting for something like this for a long time respect
I like this app, will make a couple things easier for me, now if only the free version allowed to block applications.
Notorios
That Which Is Not Defined Is Infinitely Great
Google The Search Engine Of The Gods
