Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: HELP:Network Controller Driver
    Aug 2003
    4,629
    Quote Originally Posted by Bawn_Jamaican View Post
    Thanks for the heads up. Also, i have a 5mbps internet connect from flow but when i do the speed test, after connecting the laptop to the switch, i am getting a download speed of under a 100kbps same for the upload speed.
    Do you think it's because the network controller isnt installed why i'm having that problem? Cause when i connect the internet cable directly to the machine i get the correct reading from the test.
    Im surprised you get on the net at all, NICs usually wont work without the drivers being fully installed. could just be related to the drivers.
    CompTIA A+ Certified
    MCTS - Microsoft Certified Technical Specialist - Server Virtualization
    MCSA - Microsoft Certified System Administrator - Messaging
    It wasn't me!...........okay it was but you have no right to assume!!
    537
    well if u are using a ethernet cable to access the internet and you get the correct speed when you did the speed test without the switch then is not the network controller then its the switch.
    Wise men talk because they have something to say; fools, because they have to say something. Live for computers or else they will live for you.
    8368993 (lime) 303-1359 (digi) blunt60us@yahoo.com
    Aug 2005
    486
    Question
    ok thanks.. i'm going to try this method and let u know if it works
    I downloaded the software and everytime it is about to finish.. a message appears saying that the installation has been interrupted.
    What could be causing this?
    Quote Originally Posted by The good guy View Post
    But i get the correct speed using the switch but using a different laptop on the same port with the same cable.
    So......
    Need more information? Send a PM or Email Me @ Ralphsteinhibbert@gmail.com--- You can also call me @ 377 - 5710 (no privated numbers).
    Click the blue arrow to see me
    537
    That sounds like you are using firefox to do ur download..you get that when there is errors in the connection check sent and received and see other than that use a download manager to download the file like flashget.
    Mar 2004
    812
    Make sure you have .Net 2.0 install on your machine. When you go to the link I gave you, you should see a Microsoft .NET status: which will tell you if its installed or not.
    Aug 2005
    486
    Quote Originally Posted by juba View Post
    Ok thanks... i didnt notice that and it wasnt installed. With Firefox... it was unable to be determined but when i switch to IE it told me that it wasnt installed... so am going to install it and try again.
    Aug 2005
    486
    Ok it the software installed... i just need to let it check for the upgrades that the system needs. Right?
    Aug 2005
    486
    Well i got the driver for the network controller.. it seemed it was really just my wireless card that need to be installed. However that doesnt solve the low result i am still getting from the flow speed test site. Any other suggestions?
