ok, i can confirm also stealthsim worked
i bought a brand new digi sim card about a week ago, but it didnt even work at all. last nite i just killed the battery for the iphone turned it on, and BOOM! searching . . . . DIGICEL
so yea it works, and ppl would probably be getting a keypad, recent calls, sms crashes from it after. duno if its stealthsim or the fact that jamaica isnt really a official distributed country. But i also did a hex edit on one of the iphone files which fixed it perfectly.
so far right now, im going to try edit iworld to see if it stops the crashing with the stealthsim that causes a "no sim" from time to time.
just a note for anyone with stealthsim or planning to get one, if it shows no sim, try rebooting, most likely it will be back online with ur network, well it worked for me
and for the ppl asking about stealth sim, it aint cheap but it works for all versions supposingly w/o software edit. i can get it shipped for ppl for a small toll, but i wont guarantee if it works for u or not. but the base price to get one shipped to u is around 140 - 180 usd, 140 is the minimum i believe if u get it shipped in bulks
anyways, will update with w/e happens with iworld
