What about this one? 500W vs the 430 you propose - I'd rather err on the side of power needed.
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
PC - Ubuntu 15.04 64bit Desktop
HP Pav G60-236US 3GB RAM Laptop, Ubuntu 15.04 64bit and Win7 Home
RIP Ramesh ...
That EA500 is a highly rated unit, and much better choice than your originals. See this It's Newegg ratings confirm that.
How do you know how much power you need though? ... I was considering a 520W PSU for a more 'hungry' system than yours, and though I'm still convinced 520W is enough based on calculations, I feel 'spooked' by suggestions that it isn't. I'm actually making a superstitious purchase of an extra 100W.
So tell me Ramesh, what is it that convinces you that you need a 500W PSU for a system that by all accounts would be served by a solid 80+ Bronze 380 PSU?
See this Toms recommendation for my reason
FSP AX450-PN PSU, Asrock Ext3 Gen3, Core i5-2500K, 8GB DDR3 1333, Gigabyte Radeon HD7870 2GB OC, S231HLbid 23" TN LCD, Spinpoint F3 1TB HDD, Hyper 212+ HSFOut of the many we will form an indivisible whole capitulating only to a single throne, and from that throne, I, shall watch over you.
RIP Ramesh ...
Did you look at the Tomshardware page I linked to? It showed a system with a 95W CPU, and a 110W GPU, and recommended a 380W PSU.
GO HERE http://www.extreme.outervision.com/PSUEngine and plug in your system configuration to get an idea of how much power you need. The configuration I linked to on Toms uses more power than your setup does (including your HD3800), and they recommended a 380W PSU. But it's best you buy as much as you can afford. This is an informative guide, but it's a little difficult to make mathematically precise measurements, so I end up being OVERLY cautious.
I haven't read it yet, was about to sleep when I saw your post and left it. I may look at it tonight when i go home or tomorrow and do the calculations as well.
I was just saying that since I don't want to buy the smaller one then have to replace it if not worthy, best to err on the side of caution and spend the $10 more. I will still consider the information in the pages your referred to me.
RIP Ramesh ...
Ok, here's what I put:
1 physical cpu
High End Desktop
AMD Phenom II X6 1055T
No overclock
2 Sticks DDR3
AMD RADEON HD 3850 512
3 SATA HDD
2 DVD RW
10 USB (considering extreme case here)
2 80mm fans
Gives me a total of 376W, recommended 426W.
The 430 seems the way to go then!
RIP Ramesh ...
WOW!! Where'd all that hardware come from? That's a lot of potential USB devices. When I did a rough calculation before it was way lower than 376W. If the PSU calculator recommends 426W, I suggest you get the 500W to prevent the PSU working too hard to produce what you need.
Ok, planning to get an EVGA 560ti Superclocked video card and wondering if my power supply will be compatible with it:
The GeForce GTX 560 Ti SC:
Power Supply:
Sorry for the bright light, forgot to turn off flash.
Anyways was reading the requirements for the card and they mentioned below that it requires a 500 power supply which I have, but not sure about the voltage part. Anyone able to explain this?
Requirements specified:
Current Android - OnePlus 7T Pro
PC Specs - Motherboard: Asus PRIME B560-PLUS | Processor: Intel Core i5-11600K (stock) | Memory: 32 gigs Corsair Vengeance DDR4@3200mhz | Video Card: ASUS ROG Strix GeForce RTX 4070 (OC Edition) | Monitor: ASUS TUF Gaming 27" 2K Monitor | Steam ID -> Powpow
Ok, this version is already overclocked so does this mean that even though you said this PSU rating is 25 Amps it will still manage the 30 Amps that the card requires?
I don't plan to do any overclocking on this current rig. Just running everything on default settings for now.
