dude i know what your saying buy just try. it help me with my soundcard problem, honestly, no jokes yute.
From wat I see going on, the problem could lie in one of the two areas:
1. Software, drivers need to be reinstalled, etc, normally system restore would work to fix this error, or if its a problem with windows, u could use the XP install cd and do a repair of the windows directory.
2. Hardware, if this is the case, then ur royally screwed, especially if the system does not have international support. The hardware problem wold range from bad cable within the system to simply a bad drive itself that needs to be replaced.
Neways yute, good luck
01001101011110010010000001101001011011100111010001 10010101101100011011000110100101100111011001010110 11100110001101100101001000000110100101110011001000 00011100000110010101110010011100000110010101110100 01110101011000010111010001100101011001000010000001 10001001111001001000000110110101111001001000000110 00110110111101101101011011010110111101101110001000 00011100110110010101101110011100110110010100101110
Click Here for translation
When I get home I will try the system restore option and hopes that fixes the problem.
........After all this talk, at nights we still Click "Start" to "Shutdown" and still own a Digicel phone.
you know what i think thats what the system restore fixed. all it did was go back to the initial drivers for the soundcard or if the drivers where currupted at (an imaginary point B) the restore took it back to point A where it was working fine.Originally Posted by blindz
I'm guessing you need to get the power connector for the CD-ROM drive or the drive itself checked out.
.:] ^ [:..:] Game IDs: xfire_ropy | BC:BC2_ropy | BC: 2142_ropy29 | BF3_ | steam_ropy09 | LoL_ropy09 | Origin_ropy29 [:.
But it has power, remember that the cd spins for about 5 seconds and the light is blinking on the cdrom, but after the 5 seconds it just stays on.
bwoy it ruff pon you yute, you just aint got no luck
that sounds to me like the drive is not reading the CD's then. Check the lens, and or the connectors.Originally Posted by MiTcHiE
and if that fails you know what you should do, send your satalite back sorry man life sucks and then you dieOriginally Posted by blindz
Ahh, the keyword here is 5 secs (I think). The fact that the drive spins for 5 secs each time might mean you have a power prob.Originally Posted by MiTcHiE
