Results 1 to 10 of 10
Thread: System.ArgumentException error
    keroed1 Guest
    Default System.ArgumentException error
    can anyone help me with this problem i having when some persons try to view my website they get the following error message
    Exception Details: System.ArgumentException: Invalid value for 'encryptedTicket' parameter
    source error
    httpcook = Context.Request.Cookies["authCookie"];
    formsAuthTicket = FormsAuthentication.Decrypt(httpcook.Value);
    genIdentity = new GenericIdentity(formsAuthTicket.Name);
    Jul 2006
    239
    I think that your issue comes from the first line. You're expecting a cookie to be there when there might not be one. Also, remove context, request will use the current context by default.
    Try This:
        if (Request.Cookies["authCookie"] != null) {
            httpcook = Request.Cookies["authCookie"];
    keroed1 Guest
    Quote Originally Posted by redbwoy View Post
    Try This:
    if ((Request.Cookies("authCookie") != null)) {
    httpcook = Request.Cookies("authCookie");
    oh ok cool when i get back into office i try what you said. i will post the result what should i do if it is null?
    Jul 2006
    239
    Quote Originally Posted by keroed1 View Post
    If its null, then you need to create the cookie so the next time the user comes back they will have the cookie you're looking for.
    keroed1 Guest
    this is what i did
     if ((Request.Cookies["authCookie"] != null))
                roles = formsAuthTicket.UserData.Split(separators);
                genPrincipal = new GenericPrincipal(genIdentity, roles);
                HttpContext.Current.User = genPrincipal;
    its still not working but but the program enters the if statement because it say the exception occurred at formsAuthTicket = FormsAuthentication.Decrypt(httpcook.Value); so it seems that it is unable to decrypt but next thing i should say anyone who is a member of IM[our it department] it works perfectly is when a normal user tries to view the page that it throws that error
    Oct 2005
    745
    Either httpcook.Value is a null reference (Nothing in Visual Basic).
    - or -
    httpcook.Value is an empty string ("").
    - or -
    httpcook.Value is of an invalid format.
    http://msdn2.microsoft.com/en-us/lib...n.decrypt.aspx
    Try testing against the value of the Parameter before passing it into the Decrypt function
    3.14159265358979323846264338327950288
    4197169399375105820974944592307816406
    28620899862803482534211706798 pi 101
    Jul 2006
    239
    Yeah, "recursion" is right. It could be that the cookie is there on their machine but it has no value or the wrong value in it. It would be best if you could put a break point in your code and step through and see what the values are.
    i would also put a conditional statement in it. Something like this:
                if(!String.IsNullOrEmpty(httpcook.Value)){
    Oct 2005
    745
    He says it works for machines in his department so debugging might be a bit difficult for the testing he requires. He might have to set up some Traces or if possible connect the debugger to the process on the remote machine in the other department.
    keroed1 Guest
    Quote Originally Posted by recursion View Post
    yes it works for me fine as a mater of fact everyone my it department it works fine is jus other normal users that it gives that error i skipped the entire getting roles and ecyrpting the cookie and jus created a cookie that gets the user name and then checks for the roles thats sloopy in the sense that thats not how its normally done i think when i get to work will post what exactly i did
    keroed1 Guest
    this is what i did
     protected void WindowsAuthentication_OnAuthenticate(Object sender, WindowsAuthenticationEventArgs e)
            FormsAuthenticationTicket formsAuthTicket;
            HttpCookie httpcook;
            HttpCookie cookieName;
            String encryptedTicket;
            String strUserIdentity;
            DBconn getUser_Roles = new DBconn();
            strUserIdentity = e.Identity.Name;
            string[] temp = strUserIdentity.Split('\\');
            strUserIdentity = temp[1];
            cookieName = new HttpCookie("cookieName", strUserIdentity);
            Response.Cookies.Add(cookieName);
        protected void Application_AuthenticateRequest(Object sender, EventArgs e)
            // Fires upon attempting to authenticate the user
            GenericIdentity genIdentity;
            String[] roles = new string[5];
            String rolesString;
            char[] separators = { '|' };
            GenericPrincipal genPrincipal;
            string user = Request.Cookies["cookieName"].Value;
            genIdentity = new GenericIdentity(user);
            rolesString = getUser_Roles.GetUserRoles(user);
            if (rolesString != null)
                roles = rolesString.Split(separators);
            else
                rolesString ="normal";
