Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: HELP: insert data into 4 mysql tables
  1. #21
    Feb 2006
    4,242
    That is what I had:
    PHP Code:
    $query mysql_query('SELECT * FROM name, address, phone, computer WHERE ( (name.id = address.id) AND (name.id = phone.id) AND (name.id = computer.id) ) ')or die (mysql_error());
    while (
    $result mysql_fetch_array($query))
    //echo statements here to display records.
    I don't get any time as yet to research the INNER JOIN and implement it, problably you could quote the example 4 me, so that I get an idea for this;
    --- www.fashionsJAMAICA.com ™ -|- www.ChampsJamaica.com
  2. #22
    Dec 2002
    500
    the query you entered would be equivalent to this join
    SELECT	*
    FROM	[name] inner join address
    		on [name].[id] = address.[id]
    	inner join phone
    		on [name].[id] = phone.[id]
    	inner join computer
    		on [name].[id] = computer.[id]
    -- WHERE [name].[id] = 007
    ... in SQL Server name and id are reserved so i put them in braces
    can you state the error message, if you are still getting one.
  3. #23
    3,184
    @utech22 you need to run the insert queries separately, one after the other. preferably like this;
    $query = "INSERT INTO computer (brand,type,..) VALUES ("Dell","Laptop",..)";
    mysql_query($query);
    if ( mysql_errno() | mysql_error() != '') {
       Die('<div>A Database Error has Occured : '. mysql_errno().": ".mysql_error()."</div>");
    get the point?
  4. #24
    Feb 2006
    4,242
    I was thinking about that, but since I got the functionality, I did'nt bother to change it, but I do so now.
    I am googling and browsing the php manual to get the select with inner join;
    Some help still needed though.
  5. #25
    3,184
    The php manual won't necessarily teach you to join. You have to read up on SQL queries. This wikipedia article seems general enough and should help you understand the concept;
    http://en.wikipedia.org/wiki/JOIN
  6. #26
    13,269
    34
    W3Schools is also a beginners place to start as well: http://www.w3schools.com/sql/default.asp
