Sup ppl?
I got a 1 Gig SanDisk flash drive. I was copying a 300 M.B. file to it a few days ago when a balloon appeared above the system tray saying:
Windows Delay Write Failed
*something like* The file Windows was trying to save to E: (the flash drive)
has failed. This might be caused by a bad network connection or hardware.
Please try saving the file somewhere else.
I keep getting that error everytime I try to transfer files to or from the Flash Drive, reguradless of the computer I use. I tried to format it in Windows, the Command Line, Safe Mode and Safe Mode with Command Prompt but I keep getting an error saying "The drive is in use" Even when I run the command to unmount the drive before format.
But when I run check disk to just scan the drive, it works, and it tells me there are errors on it and I should run check disk again with the fix errors option, but when I do that, I get the same errors as when I run format.
I was thinking of trying to use format and check disk on the flash drive as soon as the computer starts up, since as the errors say the drive is in use.
Also, I was wondering if there is some kind of software that can repair drives, as well as any suggestions you ppl have.
Thanks in advance.
-Des
