Results 1 to 8 of 8
Thread: Help With Bearing Movement
    Feb 2005
    139
    Default Help With Bearing Movement
    Greetings, all! Just need a little help with movement of objects in a more complex fashion - using bearing.
    I want to move an object at specific degrees but the following isnt working.
    //Main Class
    public void createBullet()
        Bullet b = new Bullet(getWidth()/2, getHeight()/2, 33, 3);
    public void run()
        while (bRunning)
            try
                b.move();
                b.paint(getGraphics());
                Thread.sleep(tickTime);
            catch (Exception e)
                bRunning = false;
    //Bullet Class
    //declaration stuff
    int x,         //Current x co-ord
        y,         //Current Y co-ord
        pX,       //Previous x co-ord
        pY,       //Previous x co-ord
        bearing, //Direction in gegrees of movement
        speed;  //velocity
    //some other stuff
    //Constructor
    public Bullet(int sX, int sY, int sBearing, int sSpeed)
        //'s' means Start
        x = sX;
        y = sY;
        pX = sX;
        pY = sY;
        bearing = sBearing;
        speed = sSpeed;
    //move method
    public void move()
        //convert bearing to radians
        int angle = bearing * 2 * Math.PI / 360;
        //Set previous x & y co-ord
        pX = x;
        pY = y;
        //Use trig functions to get new X an Y co-ords
        x += Math.cos(angle) * speed;
        y += Math.sin(angle) * speed;
        //Mirror the bearing if the x reach the side of the screen
        //and all that.
    //Paint methos
    public paint(Graphics g)
        g.setColor(new Color(0, 255, 0));
        g.drawLine(pX, pY, x, y);
    Ignoring the errors if n e, the code works, however the movement is definately not rite. I hope u get wat im saying, and if n e 1 has n code for the angle movement post it. l8er
    Do not live your life in fear, 'cuz if you do, you will never live your life.
    Sep 2005
    55
    Haven't looked at the code thoroughly but your angle variable should definitely be a double and not an int!
    1,905
    21
    I would second codex except that I am away from my dev machine to know how java handles int.
    I remember having a problem with sin and cosine w.r.t. the sign in a problem the other day and it was solve using an alternate function tangent, but that will not help you. Only test with different angle ranges, eg angle between 0,90,180,270, and -0,-90,-180,-270
    Remember also that the y display is negative to traditional y in coordinate geometry.
    1,905
    21
    Try adding a displacement vector to the bullet class
    Then set the values once you get the initial bearings.
    //Constructor
        //'s' means Start
        x = sX;
        y = sY;
        pX = sX;
        pY = sY;
        bearing = sBearing;
        speed = sSpeed;
        dX; //displacement vector
        dY; //displacement vector
        //Note sine use for X
        //The convention i used is to have Y up, X right and angle clockwise from up
        //calculate angle in rads from bearing here
        dX = Math.sin(angle) * speed;
        dY = Math.cos(angle) * speed;
    //Once displacement vector is set then add displacement on every frame in Move()
    //Reflect displacement vector on boundary condition
    //move method
    public void move()
        pX = x;
        pY = y;
        x += dX;
        y += dY;
    I still have not fixed the issue with display y is negative of the convention of y coordinate as up
    The code is the same but I was just addressing one of the minor errors.
    To fix the y sign issue , use
        dY = - Math.cos(angle) * speed; //negative here
    //move method
    public void move()
        pX = x;
        pY = y;
        x += dX;
        y += dY;
    Hope that helps, but test for different ranges of angle because I think that cos function works funny for some angles.
    BTW, how does the movement look for what you have
    Sep 2005
    55
    Let me be more verbose about the "angle is an int" problem.
    The line
    is supposed to transform the bearing from degrees (0 - 360) into radians (0 - 2*pi).
    If bearing is 90 degrees, the result should be 90*2*pi/360, which is pi/2, about 1.57.
    But angle is an int, and it will end up as 1 (no rounding)!!!
    The difference is 0.57 in radians, which is almost 33 degrees! That is a big difference.
    Furthermore, how do you compile your code? My compiler doesn't allow that line at all, because you cannot assign a double (the expression on the right side of the assignment is double because of Math.PI) to an int variable without explicit casting.
    Feb 2005
    139
    Default My Bad
    Well, the 'int angle' was a typo, and all the code was typed quickly from out of my head, i had to hurry cuz i was at taits internet cafe. I know radians are in doubles. Thanks for the info on the y co-ord, ill try it out. I guess that the y co-ord thing was the problem, ill let ya know.
    the first thing that popped into my head has already been said...darnnit
    java x,y coordinates are flipped...that's all i had to say *sighs and leaves*
    life is a game, and i'm a gamer, but my computer needs an upgrade
    Feb 2005
    139
    well, i figured it out. It seems the following worked,
        double angle = bearing * 2 * Math.PI / 360;
    when the following didnt.
        x += (int) Math.cos(angle) * speed;
        y += (int) Math.sin(angle) * speed;
    hmmmmmm, the '(int)' casting part seems to prevent rounding. im gonna investigate.
