Results 1 to 7 of 7
Thread: CHKDSK problems
    Jan 2003
    3,004
    Default CHKDSK problems
    I have a 100 gig hard drive with 2 partitions. The smaller partition is 20 Gigs exactly, and it is empty. The problem is everytime i boot, windows checks the disk for consistency and blah blah blah. It never finds anything wrong with the disk, yet another disk check is scheduled.
    I know this because when i try to defrag that partition i get an error saying that it cannot be defrag because a chkdsk has been scheduled on that partition.
    1. Is there a possibility i have a problem?
    2. Can the scheduling in CHKDSK be disabled?
    Nov 2002
    5,720
    Country
    Jamaica
    Default Re:CHKDSK problems
    What is the file system of the affected partition?
    Jan 2003
    3,004
    ntfs
    2,548
    format the smaller partition and see how that goes....
    Jan 2003
    3,004
    i sorta got rid of the problem, i put some data on the trouble partition, the re installed xp on the other partion. I got the same chkdsk at startup once and havent seen it since. I still dont know what caused it in the first place.
    1,257
    Seems there is a problem with the particular partition possibly a bad sector..........Try using a program Like Winternals or Norton System works to run a full diagnostics......I would not put any important data on this partition, I had a similar problem with a HDD which failed several weeks later ??? ??? ???
    6,128
    Country
    Jamaica
    Another possibility, since chkdsk did not find any files on the empty partition, that might have been interpreted as if the program never checked anything and so did not set the "I checked this partition already" flag. Just a thought. :-)
