Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: "Unbreakable Codes "Quantum Key Distribution System
    2,546
    Default Re:"Unbreakable Codes "Quantum Key Distribution System
    yes but the cost.....darn....either that or there is a slight misleading in what they actually say.....me nuh trus dem iah...me nah seh te thing dun work....jus how it work..... ???
    neva know we that advanced yet.....
    if these devices be true, that will revolutionise the way i work or rather the instruments i use.....
    2,546
    let me expand on what i mean crypto...yu will see what im saying....
    Its 730 m free-space link, which uses a stream of single photons
    Although the transmission distances have steadily improved over the past few years, the current records are 150 km in fiber and 23 km in free space
    This synchronized detection helps distinguish the QKD photons generated by a pair of 845 nm VCSELs from stray light such as photons from the Sun and thus raise the key transmission rate
    a single photon travelling that distance in a fiber without absorption? think of the error rate due to absorbed photons...a fiber is not really a true mirror is it..
    you distinguish a photon from the background photon?
    absolutely no way....
    it must be that its a bunch of photons. wave packets behaving as one.....
    how do you transmit info in a single photon....i hate when they get their descriptions wrong.......i'll try to find this on nist.....
    2,546
    found it...both the nist reference and the actual paper if you are interested.....it does show its a burst pulse.....
    http://www.nist.gov/public_affairs/r...uantumkeys.htm
    http://www.opticsexpress.org/view_fi...%2BJ0%20%20%0A
    second paragraph in introdcution section of the second link.....holds the clue to what they are actually saying....plebs...
