im having problems with these questions.
1)Write code that defines a structure named time, which contains three int members.
2) i)Write code that performs two tasks: defines a structure named data that contains one type int member and two type float members, and declares an instance of type data named info, ii)how would you assign the value 100 to the integer member of the structure info?
3)Write the definition for a structure type named data that can hold a single string of up to 20 characters
plz help cause my mind is blank when it reaches to this topic!!
