Oct 22, 2003, 10:35 AM
#11
Re:Wireless Network _GPRS
Specs... what exactly are you looking for on the card, dimensions or capability?
Oct 27, 2003, 01:11 PM
#12
[quote author=]<c4u link=board=26;threadid=1895;start=0#msg20963 date=1066779032]
do you know the specs on this card iG?
Specs of the Sonyericsson GC75 GPRS PC Card Modem:
- Type II PC Card - fits any laptop PC.
- GPRS, HSCSD & standard CSD - comprehensive choice of connection methods.
- Triple GSM band (900/1800/1900 MHz) - for broadest possible global access.
- Works on five continents, in over 175 countries.
- Non-extended card - the GC75 PC card fits completely inside your laptop.
- Compatible with Windows® 98SE/ME/2000/NT4/XP/ Pocket PC 2002 operating systems
- Detachable antenna rotates through 360°.
- Power supplied by laptop battery.
- Microsoft® WHQL Certified
- CE, FCC, GCF, GSM, Canadian, iDA and PTCRB Certified (after extensive testing).
Oct 28, 2003, 08:19 AM
#13
If you can deal with the inconvenience of having to use a flat surface or if you can find a connecting cable, you could just get a regular GPRS capable phone to perform these functions as opposed to getting a separate unit that you'll just periodically use. The very inexpensive Sony Ericsson T310 or T316 performs quite well using infra red.
