Results 1 to 4 of 4
Thread: OS X Security hole allows remote system control
    1,389
    Default OS X Security hole allows remote system control
    ;D... for all o the peeps busy wt winwoes.. I decided to be a little out-of-character and highlight that a hole was found in Mac OS 10.2.2 that allowed a remote user to take control of the system ....
    just a little sumthin to take the heat off my childhood OS and highlight that no man-made creation is perfect... and that tho Mac OS X is admittedly the best out there especially when it comes to security and stability (yes it is higher rated than Linux for all the Linux peeps out there) there are holes to be found!
    blessings
    - PS: the patch was released recently, which is how I found out about the hole -
    2,546
    Default Re:OS X Security hole allows remote system control
    mac attack! ;D
    Nov 2002
    5,713
    ....The Apple got holes... someone catch that blasted worm. ;D
    611
    Ok..I gonna patch that G4 now.
