I still do not get the solution (icymint3's and Tocoder's), but I can read it over and over til I do.
icymint3, you are the real big man on problem solving and making efficient programs
its a heap, the second part, i just did it on 2 lines thats why you cant see it.
the third line is to control the number of columns. maybe i should just implement it as a list so you can see clearly what is going on when you trace the program.
Your code is pretty intense. That's a compliment. You do not have to recode anything. I will just stick to your psuedo explanation, provided that is what you used in the final program. OK that code bad I would not change anything.
