Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 43
Thread: Window Washer Problem
    Dec 2002
    500
    this is really easy once you can understand the problem, and then visualize it. the zig zag fashion has nothing to do with the solution. only that a particular number of columns are done by each worker.
    if the job is done in the minimum amount of time, then all workers (who worked) finished their work in just about the same amount of time.
    assume ri is the speed the ith worker washes at.
    assume wi is the number of windows the ith worker washes.
    we want the minimum for cost = Sum(i=0 to n, ri*wi ), or something like that.
    cost = aA + bB+ cC + dD + ...
    a is number of window, A is rate...
    total windows = width * height = a + b + c + d + ...
    if every body does almost the same amount of work,
    AvgTime = aA = bB = cC = dD = .....
    if x persons do work... then
    cost = x * AvgTime
    that should help, my code goes a bit further though, hope you people understand it.
    1,905
    21
    Yes the solution is simple
    Do a brut search of all possible options, and select the one with lowest cost.
    //vary the amount of workers
    for( 1 worker used to all workers )
    //when the amount of workers is fixed, vary the names selected
    for( all combinations of the workers used )
    //when you have a particular team, vary the amount of windows they each must wash to complete.
    //eg if 50 windows must be washed by 5 people, then 1 can wash 46 and the others can wash one each
    for( all starting positions of the workers )
    //Calculate sum
    for( all used workers )
    ....sum += worker time * his windows;
    ....if sum > min_sum goto next possibibilty
    This is one implementation and no means the only one.
    This could be done in about 50 lines, but I would take probably 200. I realized I use unecessary logic in my algorithm implemetations.
    1,905
    21
    Here's a more interesting problem
    ParkingLot
    I am not attempting this one, because I fraid it send me to the madhouse.
    Jul 2005
    75
    Crosswire 'Parking Lot' is not very hard either. You just have to do take a things into consideration. Infact one thing how quick from the store to the spot you park, multiply it by two and you have time to walk to store.
    Well let us hope i read the problem correctly. If i did that is the complexity of that problem.
    "A computer once beat me at chess, but it was no match for me at kick boxing." - Emo Philips -
    1,905
    21
    I agree that it is not that hard still, but IMO, it is harder than the previous.
    I think something is missing about it but I have to read it again.
    Dec 2002
    500
    Quote Originally Posted by crosswire
    No!! never, i say never use a brute force algorithm unless you know absolutely nothing about the problem(which is impossible).
    always use all that you know. like for example we can order the set of work rates.
    then we know the persons who work slow might end up doing less columns than faster workers.
    so when we find the average work time, we divide by the work rate and find the number of columns he completed.
    we then remove that number of columns from the work schedule and remove the worker... Chip and Conquer.
    //Calculate sum
    we dont sum the work times of each worker, no. we find the work times independently, and find who took the longest, thats what we do.
    Jul 2005
    75
    Well icymint3 calm down, hold off on the caffine. LOL.
    But i agree with you brute force is so, what is that word i am looking for............. Ahh yes the word is "ineffiecient". Very few problems require brute force. We need to gently caress the problem until it open up and divulge it's secrets to us. Now the better you caress the problem the more effiecient the solution you will get.
    1,905
    21
    Yes it is IN-efficient
    About the ParkingLot problem, I just read it. Before,I read something wrong. 1) I thought that two cars were not supposed to pass through the same square at the same time, but they can. 2) I thought that a person can walk to diagonal squares but he can only move up/down/left/right. Thus I said the problem was difficult. A car blocking another car for a certain time would have been interesting.
    1,905
    21
    Back about the WindowWasher problem,
    I like that idea. I will use it in optimizing other programs.
    Well I did not see that mathematical solution... I was not looking. Anyway that sounds logically smart. Use the fastest worker to do his share. That I realized after attempts to scrutinize your solution, we all cool. Only one minor problem, how would you handle the decimal fractions, if any?
    Let me change a bit, I am all two thumbs up with efficiency, but the accuracy of the algorithm is important (especially in TopCoder competition). There is also a time limit on how long you have to come up with a working solution. I am not sure that an efficient algorithm will give you more points unless stated in the problem. It however is good practice.
    Dec 2002
    500
    sorry bout the tone, it was this book i was reading (Catcher in the Rye - J.D. Salinger) and the narrator is very sarcastic. it kinda over-powered me a bit.
    use integer division it forces ( to round ) down those (slow) guys you make do their bit of work first.
