Xamp by apachefreinds is very good, its better than wamp in my own opinion.
Nut im serious xamp is better do a google search.
Pc= Hp dv6t
I just installed php and apache server (independently) on xp home, but for some strange reasons apache server wont start.
Anyone with apache server on xp home??? :F1
--- www.fashionsJAMAICA.com ™ -|- www.ChampsJamaica.com ™
yes.
the error:error after trying to start Apache from Computer Managment -> ServicesThe Apache2 service has started and stop. Some services stop automatically if they do not have any work to do...
I evem tried Wamp5 .../did not work for me/...I uninstalled it, and is now trying Xamp but it seems to have the same prob for me...
I recommend Apache2Triad, it is the best LAMP software. Very good benchmark results. it as all you need. List of software provided:
Servers:
* Apache (web server)
* MySQL (database server)
* PostgreSQL (database server)
* XMail (e-mail server)
* SlimFTPd (ftp server)
Interpreters:
* PHP (scripting language)
* Perl (scripting language)
* Python (scripting language)
Graphic User Interfaces:
* Apache2TriadCP (control panel)
* phpMyAdmin (MySQL GUI)
* phpPgAdmin (PostgreSQL GUI)
* phpSQLiteAdmin (SQLite GUI)
* AWStats (webserver monitor)
* UebiMiau (E-mail client)
* PHPXmail (XMail GUI)
* PHPsFTPd (SlimFTPd GUI)
Have any of you tried EasyPHP, Ive been using it for a couple of years to run Apache+MySQL+PHP and found no problems with it so far. Installation is a piece of cake.
A lot of extensions are pre-compiled such as the GD library, in order to activate them its just a matter of uncommenting the extension and restarting the server.
||| Knowledge is Power |||
hmm wamp never fails.. nor does appserv. :s.. confused.. i dunno mang.
yeppp...amm... gentlemen... im assuming were on windows, so another simpler alternative is to install apache2triad, comes with every thing.
even ssl i belive, ohh and its all set up for u...(sets up the php/perl/mysql/postgresql and otehr stuff)
i used to use it all teh time..b4 i switched to linux
but check it out..it may be ur head ache free solution.
Powerd by mother & God
Get scheißen done!
OK here's my 2 cents. I got them up and running after a few days of figuring out how they blend. Its been a while but there are a few things I remember that gave me hell.
1. If your running Skype (maybe anything else that uses the same port), shut it down or Apache won't start.
2. There is a php dll that you need to change in the apache 2.xx conf file for it to work (can't remember which one but google it, you'll find out). Maybe they fixed that in recent builds...
3. If you can't get mysql to start the service after a few tries its a lot easier to just reinstall than try to figure out what went wrong. Once you have it up you won't have to worry about it again cuz it won't give anymore problems. When reinstalling remember to delete the mysql folder and manually stop all services because it won't delete everything when you uninstall and you'll be back to square one when u try configuring the instance again.
Thats all I can remember now but I'll post more when it comes back to me.
Oh I just remembered about the Zend Core. Easy to install and you have the option of having mysql and apache installed with it, plus it makes administration much easier. Basic package is really nice for anyone setting up a staging server.
