Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: Cable vs Fibre
    681
    Quote Originally Posted by datdread View Post
    To all
    How often does the Digicel Play external IP change?
    My Digicel Play is configured with an external IP address in PPPoE mode and it recycles every 48 hours. Not everyone is set up this way though so YMMV.
    Mar 2011
    483
    Are you doing any port forwarding? If so, got any tips?
    681
    Although I'm bypassing it now, prior to this I have used Digicel's router for port forwarding. Worked fine. Their equipment supports UPnP but I set up the forwarded ports manually. It also supports DMZ so you can just send everything to a system on your network as well.
    Mar 2011
    483
    681
    Those results look...erratic. Is that typically what you are seeing at all times of the day? I'm curious, do local speed tests (e.g. Speedtest.net) show the same result? Also, is that a wired connection or are you on WiFi?
    Mar 2011
    483
    Quote Originally Posted by Goucham View Post
    Yep. Pretty consistent so far. Am wired. Wasn't this bad with Flow. Waiting to hear for tech.
    https://pasteboard.co/HAIW7Fq.png
    681
    A Speedtest.net test to a Digicel server in Kingston should never look like that so something is definitely off with your connection. Hopefully their networking team can sort it out quickly.
    Here are the results from a couple of tests I did a short while ago. The download speed in these is slightly lower than what it should be because some bandwidth is being reserved for QOS purposes.
    http://www.speedtest.net/result/7579598831
    http://www.dslreports.com/speedtest/37697840.png
    http://openspeedtest.com/results/23053188
    4,948
    20
    When power goes I still have internet. My Flow modem is plugged into a UPS...
    Your modem being plugged into a UPS means nothing if the node/s you're connected to have no backup. You're one of the luckier ones. To put it in perspective - I have a 1500VA UPS at home on my equipment. Where I lived before (less than 10 minutes drive from where I live now) whenever there was a power cut I'd still have net. Now where I live once it burps the Internet goes down for 1-2 minutes for the node/s to reboot.
    Your issue may need a tech. But I don't think it will improve your ping. Correct me if I'm wrong, but Digicel is actually buying/renting bandwidth from FLOW - and FLOW allows it because they make money either way. What they do to mess with Digicel is the way the traffic is routed - so even though it's a FTTH connection you have higher ping than if you were on the FLOW network. Speeds are smashingly good though - usually.
    Oct 2009
    395
    11
    My ping with Digicel is always like 4ms
    Sep 2006
    1,262
    15
    I would think this is a routing issue as even with a local speedtest his results are off as well and the uploads are fine.
