Results 1 to 6 of 6
Thread: How to stop Snapchat using my location?
    Mar 2018
    14
    Question How to stop Snapchat using my location?
    How to stop Snapchat using my location on the Google/Snapchat I forbid it from the settings and yet again I appear on the map. Please help me out!
    Hi. You need to go into the settings area for your phone and disable the permission for location services specific to that app. So it would be "SETTINGS/APPS/SNAPCHAT/PERMISSIONS/LOCATION" or something to that effect. Knowing the type of phone or OS version may help a bit.
    Sep 2016
    93
    Quote Originally Posted by SamPossible View Post
    You need to go into ghost mode. In the app, tap your bitmoji/profile pic, tap the cog (settings) top right, under Who Can, tap on See My Location
    3,184
    Or just stop using the app altogether
    Sep 2016
    93
    Quote Originally Posted by owen View Post
    DWL, That’s not always a solution. It’s an easy setting to make within the app.
    There are also third party firewall and permission apps that may help. Some examples below.
    https://play.google.com/store/apps/d...anjia.firewall
    https://play.google.com/store/apps/d...changelocation
