Results 1 to 5 of 5
Thread: Best Mifi Solution?
    Feb 2005
    360
    Question Best Mifi Solution?
    Hey guys a few years ago I had the Digicel usb wimax modem and it was ok. I am not looking for a new option for portable wifi, any suggestions?
    What are your thoughts on Caricel?
    Which portable modems do you suggest from Digicel and Flow?
    Thanks in advance for your replies.
    Feb 2005
    360
    Any help guys? Hearing crickets.
    4,840
    Didn't see the thread. Still - it depends on where you are. If you're in Kingston it may be better to get the Caricel MiFi - if you're not in Kingston try and get one of the others. They are hard to get still. And the speeds and level of service you'll get depends a lot on where you live.
    Feb 2008
    717
    12
    Caricel is also available in Spanish Town, Portmore and Old Harbour, these are the areas I've been and get strong signals.
    Currently: HP Touchsmart 14t
    SM-G935FD - S7 Edge dual sim: Android 7 Official
    The 3 C's in life: Choice, Chance, Change. You must make the Choice, to take the Chance, if you want anything in life to Change.
    Feb 2005
    360
    Thanks guys Khat17 and Dre
