Let's face it, Wi-Fi is most definitely, a service we can't do without these days and it hurts to have a crappy signal.
Now, using an old router that you have laying around, flash with the DD-WRT firmware and create a powerful range boosting wireless repeater for your home or office.
With old Technology, you can increase Internet speeds.
__________________________________________________ _____________
Router used as Repeater:
D-Link DIR 600 - http://amzn.to/25ctCM7
Router I now use as Repeater at home:
TP-Link TL-MR3220 - http://amzn.to/25cu0Kv
Other Routers I've previously used as DDWRT repeaters:
Linksys WRT54G - http://amzn.to/1RX2QxA
Linksys Cisco E3000 - http://amzn.to/1Rsr0pu
How to fix weak Wi-Fi signal?
Build a #DDWRT #RangeBooster #WiFiRepeater:
1. Log into your main router and write down the settings
​The channel your router is broadcasting on
The exact name of your Wi-Fi network, also known as your SSID
The current wireless security mode - WEP, WPA or WPA2
The wireless broadcast mode - B/G, N, B/G/N, A/C
Your Wi-Fi password
Your Router's LAN IP address
2. ​Do Google search for DDWRT then select "Router Database"
3. ​Search for your brand and model router, the one you're gonna use as the repeater, of course, find the latest firmware for your router and download the file(s).
4.Start up your router (the one to be used as a repeater) and head to the administration tab or wherever the option for "Firmware Upgrade" is on your device. Choose the DDWRT flash file you downloaded and then click "upgrade" or "update" to start the flashing process.
5. ​After your router has restarted and your new DDWRT firmware is loaded, you will have to enter a username and password to start. I just use admin for both.
6. Start configuring your repeater
7. Use a tool such as inSSIDer or Wi-Fi Analyzer to see what's going on with your Wi-Fi network and that everything is functioning.
8. ​Use an app such as speedtest.net to see how well your repeater is performing.
9. ​After you've conducted sufficient speed tests and you're satisfied with the results between your repeater and main router. Set it, forget it and enjoy the improved wireless service for your home/office.
Visit Website for more videos >>> http://recarrojames.com
