Results 1 to 6 of 6
Thread: DL900 Help please!!
    Oct 2016
    2
    Question DL900 Help please!!
    Is there anyone who has the original Digicel 7042a/Dl900 firmware (With the Digicel Logo etc), been searching forever for it, Phone basically has a locked bootloader, upgraded it to kit-kat and worked fine for almost 2 weeks, started to freeze and wouldn't turn on one day, Factory reset does nothing (all files settings remain the same), ive tried other firmware on it and some go in boot-loop while some boot and shortly after i get unfortunately "apps" have stop working, cant access settings or any app because it "stopped working", then the phone freezes i have to battery pull and it wont boot again after, now when i try to turn it on its a black screen, its still detected by the PC, cant access recovery, can still be flashed but i'm at a roadblock currently, feel like i'm all out of options
    So if anyone has the firmware or any other means of assistance it would be appreciated
    P.S I feel like all this could be avoided if i unlocked the boot-loader first
    4,761
    18
    You're going to need someone with that phone who can dump the firmware for you. Unfortunately I don't, so can't help you out. Hopefully you get a reply soon.
    Apr 2008
    1,242
    i doubt we are in the same zone, but i have it
    ATI RADEON HD 5450 2GB 2048MB DDR3 PCI-E --- AMD PHENOM 2 X4 --- 2 TERRA X3 HD's ---1 TERRA X2 HD's--- ASROCK N68-VS3 UCC --- 700WATT POWER Q --- 8GiGS MEMORY OCZ DDR3 --- ATI ALL IN WONDER TV CARD --- DUAL DISPLAY SAMSUNG 32 INCH --- VIZIO SURROUND SOUND SYSTEM -----TRIPLE BOOT [MAC OSX HACKINTOSH, WINDOWS 7 ETERNITY, WINDOWS 8 PROFFESIONAL EDITION]
    4,761
    18
    Quote Originally Posted by mega man View Post
    If you have the time (and the bandwidth) you could probably upload it then PM it to him.
    Oct 2016
    2
    That would be appreciated however now it seems the phone has stopped being recognized by the PC, sometimes i get the system sound to tell its connected to the PC....sometimes, otherwise no signs of life, doesn't power on, just the LED on the front to show its plugged in, not sure if it charges since its just the LED, otherwise its seems dead, not in a position currently to buy another phone and so this is important.
    4,761
    18
    Do you know how to use ADB and FASTBOOT to check for a connected device?
