Results 1 to 6 of 6
Thread: Port forwarding with Flow Arris C542 aka TG862G
    Dec 2010
    7
    Angry Port forwarding with Flow Arris C542 aka TG862G
    Mornin'
    I was trying to forward a port to my DVR the other day and just could not get it to work.
    All is good on the local network, i can connect to the local DVR IP 192.168.1.3. everything cool.
    impossible to get the port forwarded from the modem 192.168.1.1. i've done this many times before but not on Flow and not with this Arris modem. It should be simple but there is something i aint gettin. must be the heat.
    all set in the virtual server setting to send external-port x to 192.168.1.3 port y as seen on page 74
    rebooted, checked and nothing. impossible to get though
    anything else i should set up?
    tanx
    Richard
    33
    Do you have something listening on port y?
    788
    Quote Originally Posted by rDrown888 View Post
    Mornin'
    tanx
    Richard
    The flow modem ,is it one of the wifi one?
    U need to check 1 main things before u can even think about getting it to work..
    check the modem and see what it is receiving from flow.. not on speedtest site but on the modem it self..
    Jun 2003
    1,464
    Talk to Flow Tech Support if you want to do that. There might be some config they need to do on their side for you to get that to work thats not related to your modem.
    788
    Quote Originally Posted by CyVan View Post
    IF its the wifi modem, the problem is that flow put alot of the modems into a private ip range , in order to know just do a what my ip check and then compare it to what u see in the wan area in the modem... (If u see a 100.x ip just call flow asap)
    I notice they change alot of customers private ip from public from sometime last year even business who have static..
    Dec 2010
    7
    Thanks guys
    Sorry for the late response. For some reason i was expecting to be notified by TJ of any replies. Made a second attempt this week. They've been working on it for 3 days. I am on WAN 100... That would definitely explain things. The problem is the wild goose chases Flow send you on. They are setting me up with a static IP which seems to imply public IP, so I should be on my way. I guess they don't do public dynamic IPs...
    Thank you for all your replies
    Richard
