Page 57 of 83 FirstFirst ... 747555657585967 ... LastLast
Results 561 to 570 of 827
Thread: Flow LTE
  1. #561
    My speeds vary. Here are some screenshots.
  2. #562
    936
    12
    This was done in Kingston? Mandeville? MoBay?
  3. #563
    All tests done in Mandeville. Speeds vary - probably due to network saturation or something. I also don't know if they have direct fiber to their stations so especially when that gets used up it may drop at peak times. Then there's the load balancing / traffic management which absolutely sucks on the HFC. So - let's see.
  4. #564
    936
    12
    They likely have Fibre right to site especially in Mandeville. The speed hit during the day might be as a result of the traffic on HSPA+ rather than LTE. All access technologies share one backhaul which I’m thinking is somewhere near 500 Mbit/s ~ 1 Gbit/s depending on the site and the locale.
  5. #565
    Aug 2016
    553
    8
    Don't know if anyone can help me. But my credit keeps getting reserved for data. Flow blames me for keeping data on. Even though my data is turned off. Customer care is useless, as they can't help me with the longstanding issue. This issue began in August, when I did a speed test on the LTE Network while it was in testing. I did so without activating a data plan. And forcing the device to connect to LTE. I told that to the CC agent. And they indicated that I should put the phone in 2G mode only. I really need any help I can get with this. My credit keeps getting reserved and taken away. I needed to make a call on Saturday, and could not. Because my credit was gone and reserved for data.
  6. #566
    Oct 2009
    395
    15
    Only solution is to have them remove the data from the sim card from their end and give it a day and try adding it back
  7. #567
    MoBay actually kind of shocked me. I had LTE on and off while in Mandeville it's strong and available in most places around the town. When LTE came up for a short time at one point my speed tests were 27.8Mb down and 8.9Mb up.
  8. #568
    11,129
    32
    I had a Galaxy S6 and an iPhone 7+ in hand... the S6 clocked 70+Mbps but the iPhone was only getting 40+ ???
  9. #569
    936
    12
    Different antennas... iPhone 7 is known for poor cellular performance especially on Band 4, 7 and other high band frequencies. FLOW recently tuned performance on iPhone, most specifically in regard to LTE retention.
    I just did a speed test on LTE in New Kingston and it looks like the network is under some heavy traffic. Even so, it manages to pump out near 30 Mbit/s. The upload was super solid though... that wideband LTE network was great thinking on their part!
  10. #570
    11,129
    32
    Getting better upload than download lol ... Told you that once some load goes on Flow's network you would see the real speeds.
    And Flow's load still wont be nowhere close to the load on Digicel...
    Stay Connected,..
