Page 44 of 83 FirstFirst ... 34424344454654 ... LastLast
Results 431 to 440 of 827
Thread: Flow LTE
  1. #431
    Oct 2009
    395
    15
    Yes, it is very much confusing. But base on the info you just provided. Maybe, the connected Network was Caricel. But how did my phone connect to it, and provided connected and Network information. While having a Flow Jamaica SIM card inserted?.
    Keeping in mind that caricel only has one tower in kingston.... Amazing that they broadcast from hwt yet still able to cover the entire kingston perhaps. At least that's what I saw on their coverage map when I went to their office e
  2. #432
    Aug 2016
    553
    8
    Quote Originally Posted by 876 View Post
    Wow, if thats still the case then that is some robust network configuration. Mind you, I am 10 mintues from Half Way Tree. Yet I cannot get any LTE service from Flow.
  3. #433
    936
    12
    Not really, 700 MHz can broadcast as far as the distance from Montego Bay to Kingston if they turn the transmission power all the way up, mount the tower on the highest elevation they can find and have absolutely flat land all around, alas however, they can't. Jamaica's RF environment is raught with interference however... It's even affected the SMAs ability to issue 850 MHz, 900 MHz and AWS Licenses (which FLOW owns available every slice of btw). Digicel and FLOW use custom interference filters to improve Rx sensitivity because of this....
  4. #434
    Aug 2016
    553
    8
    That is very interesting to know, I have a massive, massive tree at the front of my yard. The tree covers the entire house and our section of the roadway. I guess this is the reason why I cannot get Digicels LTE inside my house. I have to go down the road, or around the backyard away from the tree. To get Digicels LTE service. Flows signal is excellent here most of the time though, rarely any interuption on 2G, HSPA+. I hope thier LTE Network will be the same here.
  5. #435
    Jan 2008
    588
    I did a network search on my Lumia 950 dual sim phone in the Duhaney Park area it said; Lime 3G, 2G and 338 05 forbidden .
  6. #436
    936
    12
    Quote Originally Posted by dehyah View Post
    I think I got Caricel out there once back when they were in testing (before anyone knew what a Caricel was) back in December '15/Jan '16. The Lumia 950 Dual SIM doesn't have Band 13 so you wouldn't be able to see the network though.
  7. #437
    Jan 2008
    588
    Will Flow ever use the 850 mhz band for LTE in Jamaica ?
    I think in Cayman they use the 850 band, why AWS alone in Ja?
    AT&T ,I think, use 850 mhz band as well as AWS.
  8. #438
    Aug 2016
    553
    8
    I am not sure that Flow will utilize the 850Mhz band for LTE, maybe brandysull can elaborate on that a bit. I do believe that Flow will use carrier aggregation sometime in the very near future. Band 4 AWS will be aggregated with low band spectrum by Flow. AT&T uses band 4 AWS, while thier main LTE band is either band 17 or 12 700MHz.
  9. #439
    936
    12
    They're most likely to use 850 MHz in Jamaica if they don't acquire Caricel for the 700 MHz spectrum license. If they do use 850 MHz, it will 4x slower than their AWS LTE later. They can only get about 37.5 Mbit/s from it (its dimensions would be 5x5 MHz) if they squeeze GSM & UMTS into the same spectrum (or if they turn down 850 MHz 2G... which seems more likely). I suppose that if they use Band 5, it'll solely be for VoLTE purposes. Their 3G layer as of this month got a huge upgrade, making it quite ubiquitous; heightening the possibility of a GSM turndown. These are FLOW's 2 options. I've studied the situation quite a bit.
    P.S. FLOW Cayman uses 10 MHz of Band 17 LTE and, as of August 2016, upgraded to LTE-A and now uses 5 MHz of Band 2 (1900 MHz) LTE. It is however only accessible in and around the city of George Town. They own around 15 MHz of 1900 MHz spectrum in Cayman so, they have to use it sparingly.
  10. #440
    Aug 2016
    553
    8
    Hey brandysull, has Flow open the LTE Network to the Public in Montego Bay and Ocho Rios Yet?. August is almost out, so I wonder whats taking them so long?.
