I have a simple Dlink dir 600 with DD-WRT installed. It works for my PC, laptop and mobile devices.
I'll consider upgrading to an AC router when I have better internet.
For me the most important requirement of a router (or any device) is that there must be a modified open-source firmware available. I mean, what kind of 'techie' are you if you are running a stock ROM on something as simple as a router?
When its time to pick a new router I'll check Amazon reviews, then cross-check it with the compatibility list for Tomato or DD-WRT
1.8 Ghz Pentium 4 (OC'd.) / Intel P4 (478) Motherboard / 800MHz DDR / 256 Mb DDR RAM / 40GB Seagate / RIVA TNT2 Pro 32MB / 24X12X24 Sony CDRW+ / 18" View Sonic CRT / Windows ME Yes it will play Doom... i plan on trying Crysis 3 one of these days.
