Page 18 of 18 FirstFirst ... 8161718
Results 171 to 175 of 175
Thread: Flow AVS Up & Running
  1. #171
    4,811
    Ok, long story short, this isn't something the user will be fixing from what I see.
    This is a remote configuration for the most part.. and the tech will need to visit.
    • This isn't the normal fibre coaxial AVS... This is over DSL.
    From what I saw there is some configuration in the modem and the cable box.
    SmartRG modem: So everything starts from the modem > Interface Grouping
    Cable box settings, network settings > Internet > DHCP
    After you restart it should scan for channels and pull those subnets, etc
  2. #172
    Oct 2002
    1,958
    17
    Just got a onscreen notification of a new firmware update now available on Flow AVS. anyone else getting the notification and what feature upgrade comes with upgrade?
  3. #173
    Aug 2016
    370
    2
    Quote Originally Posted by DarkAngel View Post
    Jesus Yes, My box kept restarting for hours. I haven't notice any physical difference. But under the hood, I'm not seeing any major feature change. Only updated version number and some information in Spanish.
  4. #174
    Oct 2002
    1,958
    17
    Hopefully your box will stabilize soon. That information outline in Spanish I suspect is the list of updated features so I went to babelfish:
    * Navigate the Channel Guide and play up to 7 days back (catch up TV)
    * You can start the program from the start anytime (Play from Beginning)
    * You can pause the schedule recording available from any box (require USB)
    * Recording for all: recording hours available from any box
    * My Favorites and parental Control function
    * Search in the guide function
    * Programming information
    * Search for favorite programs and film
    Only the first one seem new.
  5. #175
    Aug 2016
    370
    2
    The box has now stabilized. I couldn't watch any TV yesterday because of it. It settled down about after 8:00pm. Great to see you got the chance to translate the information. The first point is indeed new, we never had that option before.
