Originally Posted by
xklusivve
so correct me if im wrong but are you guys saying that a lime 8mb is the same or even better for gaming than a flow 20mb??? if thats the case then i might end up switching to lime since i use my connection for gaming 95% of the time.
This may be correct. In order to have a proper benchmark however I'd say find someone in your area that has one or the other. I could wager that the LIME 8Mb would have similar or less latency than the FLOW 20Mb and most likely also have far less spikes. Personally I'm also thinking of switching back to LIME because FLOW has been dropping in their overall QOS.
