hey guys...my problem this time...is that whenever i apply a skin, it skins everything but the taskbar...i dont get it, i tried reinstalling and its the same thing. anyone has any ideas?
Check the settings. I think you can enable taskbar skinning from there. I don't remember exactly where, cuz I uninstalled it, but there's a menu that lets you choose which taskbar skin to use. "Force XP style" or something like that.Originally Posted by Krems
Nexus S - Android 2.3.3 CM7, Jame Bond kernel with BLN, ext4 & full voodoo
Bold 9700 - OS6.0.0.448
if you're talking about the option in user overrides...that doesnt work either, it changes the colour, but the taskbar changes to the classic windows type
Hmmmm..... Do you have any other skinning programs running or installed?
nope, only one i've ever used is windowblinds..its quite odd
really now, its a conspiracy!
but still, what version you using? i using 4.3
do you have the theme manager installed as well? try applying the skin more than once
~ >>>| Windows 7 - Tips, Tricks, Info |<<< ~ >>>| Nvidia GTX 275 vs AMD HD 4890 |<<< ~ >>>| This Week's Releases |<<< ~
~ >>>| Forum posting & you (video) |<<< ~ >>>| How To Behave On An Internet Forum (video) |<<< ~
theme manager?
tried applying it more than once....same effect
would the fact that i have different user accounts have anything to do with it?
Try themeXP.org. They are kinda better than windowsblinds to me...but they can hog memory if not properly configured.
19" LCD|Asus A8N SLI Deluxe|AMD X2 3800+ @ 2.5GHz Cooled by Zalman CNPS9500|4 x GSkill 1Gb DDR 400|2.25 TB Total storage|eVGA 256mb 8600GT DDR3 @ 640/1600MHz cooled by ZalmanVF700|Ultra X-Finity 600W PSU w/ 135mm fan|1 x 120mm|4 x 80mm|Altec Lansing AC56|Windows7 x64 : Ultimate
