Results 1 to 3 of 3
Thread: Help with MySQL join
    Aug 2005
    510
    Default Help with MySQL join
    i need to do a single query against two table as follow.
    Select item.a, item.b, item.c, count(place.d) as item_count where from item left outer join place on (item.id = place.id) where location='1';
    not the query runs just fine, how my result is not what i want. given that table place will have multiple entry for a, i want to count the amount and display it as one in a single table.
    The result i am looking a table with multiple items and a count of the id as it appears in place
    my issue is that when i run the query i only get one result back not the list, event thought my items table have multiple items and my place table is blank....
    can anyone help????
    Why fight Information Technology when you can outsource IT
    May 2004
    525
    Try adding a group by for the column that will make it un unique example item.id
    "...men are that they might have joy."
    Nephi
    Mar 2005
    161
    Quote Originally Posted by Overkill View Post
    can anyone help????
    Why your question stated so complexly. Next time use real world examples bro. But like the other guy said use a group by clause to group your items like so
    from item
    where location='1'
    group by item.a, item.b, item.c
    so each data row will look like this
    | item a | item b | item c | item_count
    | Nokia | Lumia | 810 | 5
    P.S. try indenting your code too, makes it so much easier to read
    you could throw in nolock on the table names to prevent lockups, depending on how long ur query takes to run, also alias for easier coding... just saying
    Owned:
    >> Samsung Galaxy Note 3; LG Optimus G; Nexus 4; Samsung Galaxy Ace Duos
    << Microsoft Surface RT; Dell Venue 8; Asus Transformer
