Results 1 to 5 of 5
Thread: Question i got for Practical test and solution i submitted.
    Sep 2005
    2,394
    Default Question i got for Practical test and solution i submitted.
    Feel free to give opinions and alternate way of doing it.
    #include <iostream>
    #include <string>
    #include <iomanip>
    using namespace std;
    /*TEST 1
    Requirements:
    Create a class called STUDENT with data members firstname, lastname, age finalcwgrade and
    finalexgrade and studentID.
    Use a default constructor to initialize firstname to “Usain” and lastname to “Bolt”.  Initialize
    all other data members to zero.
    Define a mutator that will accept values for the data members from the user and update each data
    member.
    Define a function CalculateFinalGrade that will sum the final coursework grade and the final exam
    grade and return the average of both grades.
    Define a utility function that will check if the final grade is above 80, and prints the message
    “This student is above average”. If the final grade is not above 80, then your program should
    display “ This is an Average Student”  This utility should be invoked by a display function.
    The display function will display all the student’s information and whether or not the student is
    average or above average.
    Finally, write a main program that will implement the student class. Invoke the display function
    before the user enters inputs to display default constructor values and should also be invoked
    after the user inputs.
    class Student {
          private:
              string firstname, lastname;
              static int age, studentID;
              static float finalcwgrade, finalexgrade, finalgrade;
          public:
              Student(){
                  firstname = "Usain";
                  lastname = "Bolt";
              void setStudent(string fname, string lname, int ag, int stID, float cw, float ex){
                  firstname = fname;
                  lastname = lname;
                  age = ag;
                  studentID = stID;
                  finalcwgrade = cw;
                  finalexgrade = ex;
              float CalculateFinalGrade(){
                    finalgrade = (finalcwgrade + finalexgrade) / 2;
                    return finalgrade;
              string PerfTest(){
                    if(finalgrade > 80){
                        string assess = "This student is above average";
                        return assess;
                    else {
                         string assess = "This is an Average Student";
                         return assess;
              void Display(){
                   cout << setw(5) << "First Name" << setw(10) << "Last Name" << setw(5) << "Age" << setw(10)
                   << "StudentID" << setw(10) << "CW Grade" << setw(12) << "Exam Grade" << setw(12) <<
                   "Final Grade" << setw(10) << "Status" << endl;
                   cout << setw(5) << firstname << setw(10) << lastname << setw(8) << age << setw(10) <<
                   studentID << setw(10) << finalcwgrade << setw(10) << finalexgrade << setw(10);
                   cout << CalculateFinalGrade();
                   cout << setw(36);
                   cout << PerfTest();
                   cout << endl << endl;
    int Student::age = 0;
    int Student::studentID = 0;
    float Student::finalcwgrade = 0.0;
    float Student::finalexgrade = 0.0;
    float Student::finalgrade = 0.0;
    int main(){
         Student stud;
         string fname, lname;
         int age, stID;
         float cw, ex;
         stud.Display();
         cout << "Enter First Name: \t";
         cin >> fname;
         cout << endl << endl << "Enter Last Name: \t";
         cin >> lname;
         cout << endl << endl << "Enter Age: \t";
         cin >> age;
         cout << endl << endl << "Enter StudentID: \t";
         cin >> stID;
         cout << endl << endl << "Enter Final Coursework Grade: \t";
         cin >> cw;
         cout << endl << endl << "Enter Final Exam Grade: \t";
         cin >> ex;
         cout << endl;
         stud.setStudent(fname, lname, age, stID, cw, ex);
         cout << endl;
         stud.Display();
         cin.ignore();
         cin.get();
         return 0;
    To find what you seek in the road of life, the best proverb of all is that which says: "Leave no stone unturned." Edward Bulwer Lytton
    Nov 2011
    263
    I'll take a look at it. When do you need a reply by?
    Phone: Nokia 1200 with Satantendo ROM v.3.3
    Laptop: (Pentium III 850 MHz, 512 MB, 60 GB)
    Console: Sega Dreamcast
    Check out my blog: http://satanforce.wordpress.com/
    Sep 2005
    2,394
    There is no rush really. As I said I got that question as a practical test on Saturday night and code you see there is what iI submited. Just want feedback on my approach and suggestion on how else it could have been done
    1,388
    Default May I interest you in further experiments/experience?
    Quote Originally Posted by lovepython View Post
    Are you familiar with Git? If you are, would you like to host your code that way? Benefits:
    1. Ease in sharing code with others
    2. Better tracking of changes and methods
    3. Multiple versions of 1 file ("God doesn't roll dice")
    4. Backup with ease
    If you are interested create an account at Github.com; then post your repository link.
    Sharing is caring? Then what if I care too much? A precarious situation, indeed...
    http://ip-check.org/ip-check.png
    Sep 2005
    2,394
    no am not familiar with it. kinda new to programming. will check it out
