Results 1 to 2 of 2
Thread: Make thumbed images with fit to box aspect ration fucntion
    May 2004
    525
    Default Make thumbed images with fit to box aspect ration fucntion
    I am working on a project in which i need to make thumbed images and maintain aspect ratio based on a set width and height. After searching the web i found examples that only helped me for one or the other need . So i combined both fucntionality into one, here is my function(this uses GD library to manipulate images):
    function make_thumb($src, $thumbdirectory,$thumbedfile, $desired_width,$desired_height) {
      /* read the source image */
      $source_image = imagecreatefromjpeg($src);
      $width = imagesx($source_image);
      $height = imagesy($source_image);
      //calculate aspect ratio
       if ($width > $height) {
        $percentage = ($desired_width / $width);
       } else {
         $percentage = ($desired_height / $height);
       $desired_width = round($width * $percentage);
       $desired_height = round($height * $percentage);
      /* create a new, "virtual" image */
      $virtual_image = imagecreatetruecolor($desired_width, $desired_height);
      /* copy source image at a resized size */
      imagecopyresampled($virtual_image, $source_image, 0, 0, 0, 0, $desired_width, $desired_height, $width, $height);
      //chk if destination exist and make it if not
      if(!is_dir($thumbdirectory)){
        mkdir($thumbdirectory, 0755);
    	chmod($thumbdirectory, 0755);
       /* create the physical thumbnail image to its destination */
        imagejpeg($virtual_image, $thumbedfile);
      }  else {
    "...men are that they might have joy."
    Nephi
    3,070
    Cool, very elegant.
    Only difference in mine is this;
    if(is_resource(@imageCreateTrueColor(100,100))) { //check gd library version
    	$desImg = imageCreateTrueColor($thumbWidth,$thumbHeight);
    	imageCopyResampled($desImg, $srcImg, 0, 0, 0, 0, $thumbWidth, $thumbHeight, $srcWidth, $srcHeight);
    	} else {
    		//version < 2.0
    		$desImg = imageCreate($thumbWidth,$thumbHeight);
    		imageCopyResized($desImg, $srcImg, 0, 0, $srcX, $srcY, $thumbWidth, $thumbHeight, $thumbWidth, $thumbHeight);
    Which probably is pointless since everybody has upgraded servers now.
